Door skins
The Ghetto
I'm currently fixing up my doors and of course on the driver's side the inside bottom portion is rusted away and needs to be replaced. I cut away the rusted part. Now, I have done some searching and I see that Heritage has doors skins sold seperately. But, I need the inside part. I thought about fabbing something but i'm not sure what I should do.
Depends what you are after. Resto, DD or beater hack? Certainly anything can be fabricated. Just takes time and time is money. I found other doors as I couldn't find anyone local that would do rust repair. I have not seen a source for the inner lower doors but that doesn't mean they are not available somewhere. Call them and ask if that is your question.
No resto really. Basically anything that won't look like crap.
I'm kind of in the same boat execpt I need both inner and outers. I've thought about trying it with fiberglass.
I also need to do the rear doors also.
I bought a set of inner and outers off of ebay bay a while ago, so I know someone makes the inners, I think Canada Cruisers had then individually for the best price. If your doors are the earlier style I would just fabricate the outside and rework or fab the inside. If you have late model doors as I do, I would even bother to try and refab the outside just buy the panels. Keep in mind you can get a whole new door for 500 bucks, so don't waste too much time in bodywork (if you outsource the job) when you can replace the whole damn thing. Hey mdjohson I assume your either a Dr. or live in Maryland. I'm in western MD past fredneck. do you belong to Capital Cruisers?-junk
Well, I just emailed Canada Cruisers so i'm sure they'll get back to me soon. I was thinking that I could take some thinner sheet metal and form it to the pass side and attach it on the inside. I don't have access to a welder which sucks. I'll have pics soon.
You could use Duramex which is a very high strength epoxy about 140 beans for the kit, BMW and Mercedes use this stuff for 1/4 panels, VERY STRONG stuff. I will be using it for the door skins on my truck but I'm a little weary about the lower door frames on the inside and will probably weld that. I like the duramex as it does not distort the sheet metal, need little to no grinding and will not rust like a typical weld not to mention it's moisture inhibiting. If I don't go with a new tub next year and just rebuild mine I will glue the 1/4's on around the wheel wells so there is no distortion and a watertight seam. Good Luck -Junker
