Door lock problems
Hi All
I have been having a problem with the door locks on my 93 cruiser. The central locking won't open the doors.
When i turn the key to the unlock postion the acuators won't fire, but when i turn the key to the lock postion the acuators re-lock all the doors. When i open the door and use the button in the drivers door cluster same problem the doors will lock but not unlock untill i turn the ignition on then no problem.
Please help it is driving the wife mad.
I have this same problem... can't help but I am interested in what others have found
Start with the above suggestion, then check your wiring to the brake lights.
Two locations come to mind:
The rear hatch to 3rd brake light(LED) and under the tire jack connections.
It is best to remove the jack and jack holder as this allows ample room, my connector was completly corroded and shorted...thereby allowing me the freedom to cut, splice, resolder and shrink wrap all the wiring in near -30 weather.
The reason I suspect a wiring issue is that all systems returned to normal after the repair.
