- Joined
- Aug 15, 2005
- Threads
- 776
- Messages
- 5,125
My doors are shaking and rattling a bit without my hardtop. I adjusted the door catches as far as they will go, but I still need just under 1/4" to make the doors close enough so they don't have any play in them. I should have mentioned that my weather stripping is not the freshest and it has shrunk and thinned.
What's the best way to redo the catches so they can be adjusted more? Drill out the holes and the threads, widen the holes and use new nuts on the inside of the door frame and replace with new bolts? I should be able to access the inside of the holes through the hard top area where the long bars drop into the body.
Or am I overthinking this and there is an easier solution besides replacing the weather strip (not in the cash funds right now)?
gets worried about her little boy falling out going down the road or if I flop. With 4 point harnesses and his full backed booster seat, he can hardly move, let alone fall out. But, it isn't worth the fight or stress to argue about the doors.
