Door issues
Scottsdale Arizona
Some of my doors need to be slamed and some need a soft touch to close then any or all will jar slightly open driving down the road :mad:is there a thread for adjusting the door hinges and such?
I don't know if there is a thread, but those hinges wear out and this happens. Depending on your rust factor and wear issues, they could also be pulling off the body...ripping metal as they go.
There is a thread here about rebuilding the hinges to remove the sag: https://forum.ih8mud.com/fj55-iron-pig-preservation-society/141743-55-hinge-pin-repair.html. Here is another that might help: https://forum.ih8mud.com/fj55-iron-...y/222044-door-hinge-rebuild-fixture-tool.html
I also seem to remember that Ige (nuclearlemon) had to do some welding on her door frame to reinforce the area because her hinges were pulling off. A wee bit of searching might turn that up too.
re
X777 I cling to "guns and religion" :)
thanks I'll look at those
any other ideas?
:popcorn:
got it
thanks
If ever you get completely fed up with the stock door latches, you might consider switching to bear claws. I'm doing that on my build and it's coming out really nice. Buck's 45LV buildup used them and they came out amazing which is what helped me decide to do mine. Well worth the effort.
Still hoping someone will come through w/ pic of inner door mechanism...
No love so far.
Wait, what do you need a picture of? I have my doors completely apart.
shoot the both side and what you have done so far:bounce::bounce2::bounce::bounce2: :p
