I decided to install a simple switch to disable the door courtesy lights when the rear hatch is open. Whether you're tailgating or camping, it is nice to have the ability to turn off the door lights. Some have resorted to removing fuses or bulbs, while some have shoved carabiners into the locking mechanism to disable the lights.
Here's a simple, one banana
solution!
First step is to go out and purchase a simple switch that appeals to you. You can use any style that suits your taste, whether it's a rocker, push-button, or toggle switch. I went with a simple SPST on/off rocker switch from my local electronics store (Fry's Electronics). Manufactured by Philmore, part number is 30-16605. Cost was under $3:
Remove the panels from the upper rear tailgate. Here are a few shots of the trim piece that surrounds the upper hatch release lever as it went under the knife (Dremel, Exacto knife, and miniature files):
solution!First step is to go out and purchase a simple switch that appeals to you. You can use any style that suits your taste, whether it's a rocker, push-button, or toggle switch. I went with a simple SPST on/off rocker switch from my local electronics store (Fry's Electronics). Manufactured by Philmore, part number is 30-16605. Cost was under $3:
