Don't do this...
Socal/ I.E.
OK I feel stupid. Yesterday I was removing my OME roof rack, so I can install my new slee full rack. To fill the holes that remained I decided to use construction style expanding foam before I applied Bondo. This worked great and I felt so smart for thinking of such an inventive solution for filling the houls (anyone that has ever removed a rear wing or roof rack can confirm that the houls left after the mettle anchors have been removed are seemingly bottomless and a major pain)
The problem presented itself late this afternoon when I triad to open my sun roof... yes it had been obstructed by the foam. my heart sank and I had a:o:whoops::mad::bang::crybaby:moment.
What is the easiest way to fix this mistake? Can I access this from underneath?
Sorry no photos there is nothing to show except my great body work.
There are solvents that will eat the foam, but will probably eat plenty of other stuff up there too.
Drop the headliner. Be extremely careful when doing so.
I've had scare moments with that expanding foam. And it does not come off. Ruined quite a few shirts that way...
Frankly I get nervous using it anymore. I still use it, but I try not to when I can.
I wouldn't use any solvents on it, probably bests to chip it out. Try removing the glass, you maybe to gain access that way?
Ok nothing to do with TLCs BUT when I was building my wife's wine cellar I had a brilliant idea that for one wall that didn't have R32 insulation, I thought I would use R22 equivalent expanding foam. We drilled a few holes and started pumping it in. Can by can by can.
Everything seemed fine. We filled it up until it came out the holes.
15 mins goes by. 30 mins. Then we hear it. POP. POP. POP POP POP!!!!
It pushed out 100% of all the drywall...LUCKILY!!!!
I had a flashing nightmare that it was pushing out the outside wall. Nope, it took the path of least resistance.
It was an absolute nightmare to cleanup.
I feel for you and now I dont feel so dumb myself :p
expanding foam is very sensitive to paint thinner.
But it is going to leave a mess.
And foam is about the worse thing to use for body filling.
Now would you all indulge me while I defend my stupidity...
I agree foam is a bad body filler. But, it is great for filling holes, it worked brilliantly in the back where there is a empty space, you just cant fill to overflowing, put about half as much as you think you need.
The right way to fill the holes would be to weld them up. Stick small bits of metal under them with tape, and weld with a wire welder. Watch for the tape to catch fire. (It will!) Also watch for sparks falling onto the seats and carpets below, (they will). Grind off and use bondo to smooth it all out. But do not use the Bondo brand, get the good stuff.
That foam is almost rigid when dry, and will make an OK base for bondo, but the bondo will crack later.
To get the foam out, you will probably have to remove the headliner. Now it is likely stuck in there by the foam. You will have to gently cut the foam from the headliner with a razor knife. I suggest the type with a snap-off blade. Extend the blade all the way and carve as needed. Remember that the headliner was at well over $1000 when I priced it 2 years ago! You would do well to be very nice to it!
There is a thread called "Sunny Belly" that details a rollover rebuild. It has many pics of an 80 (mine) with the whole interior removed,except for the dash. It contains a lot of smart-a$$ed remarks, and a lot of info. It may help you to get an idea of what you are getting into. Use that and the FSM to get the headliner out. You will have to remove all of the trim leading up to the head panel. Headliner panel removal is most of a full day for an experienced mechanic. For you it is closer to two days. Take your time. Plan to drive the truck for a week or two with the interior in a state of disassembly. You will need a variety of panel prying tools. This is not pretty, nor is it quick.
Removing the interior, straightening the roof, and putting it all back was a job of three weeks for me, full time 50 hours a week! Then I had to do the outer bodywork. I am an experienced mechanic and bodyman. It is not that bad for you, but do not expect it to be light! As a weekend labor, it will be at least three weeks, plus painting.
seems like something i would have thought was a good idea to do.;)
Brian has it right, you need to pull the headliner, and get that stuff out of your truck. What most people don't realize is that stuff can be caustic and in some cases will eat paint. It also absorbs and holds water, even out of the air. Bare metal + moist foam = BAD rust problems eventually.
The only addition I will make to Brians post is that if you want to put some scrap metal patches under the holes and weld them up (best way to patch the holes), you can SuperGlue the patches up, it works better than tape and no fire hazard.
not houls, Holes :D
Something to try (maybe)
I was recently watching the geniuses on Mythbusters and Adam was building a model (of something). Anyhow, he laid up his mold in styrofoam, poured the mold with whatever the modeling material was built from, let it set and then removed the styrofoam from the model with ACETONE. The foam dissolved completly leaving a clean model widget. I dont know if the blow foam you used is chemically the same as what he was using, but you could see the effects on a piece of leftover scrap foam. Maybe it would work???????
Good luck
BD:beer:
I can just see someone pouring acetone into the holes. And then wondering where all the holes in their headliner came from.....
Not to mention acetone will strip paint.
Seriously, don't do it.
If acetone will eat through foam, it'll eat thorugh the headliner. The "right way" to do it is drop the headliner (which is probably attached to the roof now) and extremely carefully chisel out all of the foam. It's going to be a huge PITA, and I give it a fair chance of breaking the headliner in the process (regardless of how careful you are). If it were me, I'd be saving some coin for a new headliner, just in case.
Depending on where it's attached, it may not even be possible to reach the foam when dropping it.
did it fix the sunroof rattle??? :D
seriously this might be one of those things you think about for a while to see if you really need to fix it. I only say this because i can invision a new headliner being purchased and still a LOT of labor involved. Not saying its not worth it, it all depends on the use and condition of your vehicle. i wish you the best luck.
It sucks, but I agree. If it were me, I would consider cutting the power to the sunroof, and epoxying the thing shut. **** it. Now your truck is probably super quiet.
Per Dow Chemical
GREAT STUFF™ . . . will deteriorate when exposed to sunlight so any exposed foam must be painted.
might be possible to remove sunroof & irradiate foam with UV light? vacuum crumbs out as it deteriorates?
NOTE: I only have experience with finding it in the rear quarters of a Samurai & all the negatives posted here apply X 2.
Scary Wolfie! Made with GREAT STUFF.™
Credit: Robert Vaughan of Dearborn, MI
Well, Sorry guys it was not as much fun as it could have been. I simply tilted up the sun roof, removed the casket style trim piece, and used a hand saw and hook made of wire. I just used the saw to cut and loosen the foam, then simply removed the pieces with the hook.
Thanks for the help.
Darn, no carnage!?!?
At leas problem solved :beer:
Ah. I was under the impression that the foam had attached to the sunroof.
Glad to hear it wasn't that bad.
