Technical question for 80 owners. Are the OD of your rear lower arms the same? What's the distance between axle centers front to rear on both sides? I think i have 2 problems: my rear lower arms are different sizes (od) and my distance between axles is 9'4" on ds and 9'5" on ps.
Different sizes would not matter if the links are different lengths that would matter the axle would not be straight, one tire would be further forward and cocked
Early arms are visually bigger then the later 95 arms, don't know if length changed, I would measure them both or just change them to either 94 style or 95 and up or go buy from vendor, metal tech makes nice set
They appear to be the same length from center of bolt to center of bolt. And they are true with my edge. Would a 2" rear lift cause the pan hard to shift enough to the passenger side to cause the axle to turn. My thrust angle is 1.45 degrees.
But technically the thrust angle will increase with stock arms/bars as you increase the suspension lift. Effectively the lowers will swing to the passenger side and the distance between axles would change.
The only way that the wheelbase can be different from one side to the other is if there is something broken or bent.
Raising the truck shortens the wheelbase equally on each side of the truck as all the linkgages are attached towards the center of the vehicle.
When the truck has been lifted and still has the standard panhard bars the axles will not be exactly centered under the vehicle but the wheel alignment will most likely be in spec. The axles will not twist under the truck in this circumstance.
Take the truck to. Wheel alignment shop and have me check it out.
