Does this engine block (2f) have any value?
northern utah
Hey everyone, I am new to the forum, my son and I bought an FJ 40 as a father/son Project… He is 16 And hoping this will be a good bonding experience :-) when I bought this FJ 40 it came with a bunch of spare parts, one of which is an engine block.
I was told the person she had bought this from I switched the original motor in his FJ 40 for a larger one, I don’t know anything about this motor, not even sure it runs… Question is, do I scrap it, or do I try to sell it… I would love to have some funds to pay for all of the parts I am going to need for this restoration :-)… Any advice Would be appreciated!
If the block is really a 2F, and hasn't been bored past its useful diameter, I would think it would sell for $150 or so in the present condition, but your being in Utah, better find a local buyer because shipping on something that heavy would be tremendous. Looks like it might have sat outside in the rain so, if it's locked up, worth zero. The heads for these motors are still worth something as they are getting scarcer.
Welcome to the forum. Looks like an F but the engine stamp will tell ya if it's an F or 2F.
It is an F.5 ('74) by the missing bolt hole for the exhaust header, and the older intake manifold. That, and a previous owner probably took a couple of bolts out of the head to harvest an air cleaner. It has provisions for an air rail in the head. Or, that is my best guess, because I can't figure out what is up with the single belt groove on the harmonic balancer, and how that would work with both a smog pump and alternator.
To the right person, the parts could be a life saver. But, the thermostat housing, and intake manifold might be worth more than the rest of it because all that rust makes me skeptical.
Hmmm, My 74 F.5 has the extra bolt holes or studs actually. Front & rear.
The body ID was marked 5/74.
Two groove pulley, narrow & wide. Nut for hand crank.
Don't know how to read the block stamp and cast numbers.
OP looks to be an engine from 68-70 or there abouts it is an F engine... header has value... you can get around $100 for it ... intake you can get a few bucks for as they sometimes crack in the center where the exhaust used to bolt up to... there is value for somebody
what year is your cruiser
the F doesnt have as much value as a 2F .... but... it is valueable to some.... offer it up for $50 and help a mudder out who NEEDs it... you'll be holding onto it for a long time if you want $$$ especially for an unknown (running) engine
@Steamer you have a 1F.5 motor.... engine number falls in line with 4/74-5/74 time frame.... the other number you posted is the block part number
My 2c
I am 100% sure it is an F block and not a 2F ... it has an oil regulator on the side that oil lines attach to (your missing on it)
could be upwards to early 72 .... 68-72.... can't make out the build code from your pictures.... the 11411-60031 is the block part number
the engine serial number is on the opposite side on a ledge above/forward of the starter... it will start with an F
thanks, ill try and flip it over, its very heavy :)
I would pull the manifold and header, then stand it up.
The first number of the casting date looks like a "2" so I would say a 1972 F engine.
Thank you!. Knew I had an F.5 but not the date.
My 2c
68/69 had the wide intake manifold. No oil fill on valve cover would probably be a 70 or 71.
