Does inclination affect 2F engine power?
Spain
I have been wondering for some time if when offroading going in extreme uphills, downhills or bank angles affects the 2F engine power due to the fact that it works with carburator and not fuel injection. Does anyone have any experience with this?
Thanks for the help.
yes going up hills greatly reduces the output power, but the good news is, going down hill greatly increases the power output.
Humaro, any incline effects any vehicle going up hill FJ40 or otherwise. Extreme angles effects carburetors due to the bowl, but the OEM carb is pretty good on high angles. I've never had an issue.
My baffled Holley does quite well at steep angles. The problem with most carb setups is the flooding or starving on steep inclines when bouncing or climbing over obstacles.
Thanks for all your answers, is the 3B diesel engine less affected by extreme angles than the 2F is because it is fuel injected?
If you look at the last three drawings on ebay listing #252568209402 you'll see the off road float bowl problem. A Holley 350 can be fully baffled to prevent this problem. If you are considering fuel injection, I can help.
