Does 2F have guide sleeves
Beehanger
winter projects are hell
Idaho
Rebuilding my 2F motor with a mechanic (I didn’t take it apart, first one) and didn’t find any guide sleeves in the parts sent with the engine
The mechanic is confidenced the 2F has guide sleeves and they’re just missing, but I couldn’t find them on the FSM.
Does the 2F need guide sleeves on the top of the block and if so anyone know where can I get some by Friday?
Thanks
Dan
"Guide sleeves"? Is that what they call those little round parts that go on top of the block that also fit into the bottom of the head? If so, then yes. You need two.
Where to get quickly? I might call Kurt at Cruiser Outfitters, see if he has any.
Thanks
Dan
you will need qty x 2 pcs
11434CPIN, STRAIGHT (FOR CYLINDER HEAD SET)
90253-17003L=7, OD=16.5
@ToyotaMatt Just for you bro, you ROCK!
Where can I find this diagram and others?? 2f engine FSM doesn't have this! Only reason I new the dowels were needed cause mechanic working with me noticed from experience.
Thanks
Dan
Thanks
Dan
Also since youre website doesn't sell the dowels, where's the best place em?
And on that note to all on this thread-- I'm also looking for parts like new oil pump, fuel pump, engine pulley, clutch, Carb rebuild kit ( I know a guy locally who rebuilds) etc. I find stuff on google for most parts but hard to know quality etc. I'm sure it depends for each part but any resources are helpful!
Thanks
Dan
Thanks
Dan
here is your fuel pump Dan
Thanks
Dan
There are a few places on line that have Toyota parts diagram. This is one I use. Make sure you select the region to Toyota USA and then drill down from there.
Only ones I could find on this site were for the deisel not the 2f. Partsouq has been helpful but doesn't have everything. Specific links to the ones you use would be invaluable, or instructions on where to find elsewhere.
Best,
Dan
I’m not sure what you are saying, Dan. There are guide pins listed for the 2F. Whether the pins are still available from Toyota is another matter. I was replying to your question where you could find parts diagrams.
Not a guide sleeve matter. Should probably post on a new thread, apologies. Trying to find more diagrams to figure out what overall parts Im missing, but haven't found everything I'm looking for in diagrams on partsouq or any other site.
Was able to get the engine together without guide sleeves.
Best,
Dan
