Dobinsons Suspension Toyota Tundra Options (1st & 2nd Gen)
crikeymike
ExitOffroad.com - Dobinsons Specialist
Supporting Vendor
Jacksonville Beach, Florida
Website
exitoffroad.com
**Updated 3/11/2025
Hey Guys. I've had quite a few Tacoma guys recently ask about what options Dobinsons have for the Tundra (old and new), so I'm going to break it down here with each part so that it's all easier to find for anyone in the future.
Tundra 2000-2006
Front Coils
C59-300 - 2" Lift w/stock weight, 385/385mm free height, 586LB rate (requires new upper coil isolator)
C59-302 - 2.5" Lift w/stock weight, 2.0" Lift w/110-175lbs added, 395/395mm free height, 586LB rate (requires new upper coil isolator)
C59-344 - 2" Lift w/bumper & winch, 370/370mm free height, 650LB rate (uses OE upper coil isolator) - Same as 1st Gen Sequoia front coils
Front Struts
GS59-222 - Twin Tube Nitrogas struts, 2" body, 465mm ext, 365mm comp
IMS59-50222 - Monotube adjustable height (threaded body) struts, 2.2" body, 473mm extended, 335mm compressed lengths
MRA59-A222 - Monotube 3-Way Adjustable Remote Resi struts (coilovers), 2.2" body, 473mm extended, 335mm compressed lengths
Rear Shocks
GS59-940 - Twin Tube Nitrogas shocks, 2" body, 614mm ext, 361mm comp
IMS59-50940 - Monotube 2.2" body shocks, 14.2″ compressed length, 24.2″ extended length
MRA59-A940 - 3-way adjustable remote resi monotube 2.2" body shocks, 14.2″ compressed length, 24.2″ extended length
Rear Leaf Springs
Sorry, Dobinsons don't offer a replacement leaf pack or add-a-leafs for this generation
Rear Quick Ride Kit (blocks & u-bolts)
QR59-552K - Quick Ride Kit, 1.2" lift blocks with caster correction built in and new u-bolts
QR59-551K - Quick Ride Kit, 2" lift blocks with caster correction built in and correct length u-bolts
Individual item page: Tundra 1st Gen (2000-2006) Archives | Exit Offroad
Tundra 2007-2021
Front Coils
C59-778 - 2.5" with Stock weight (662LBF/in spring rate)
C59-610 - 2.25" With bumper and winch weight (737LBF/in spring rate)
C59-780 - 3.0" with Stock weight (662LBF/in spring rate)
C59-578 - 3.0" With bumper and winch weight (662LBF/in spring rate)
Front Struts
GS59-710 - Twin Tube Nitrogas struts, 2" body, newer extended length to suit 0-3.5" lift heights
IMS59-60710 - Monotube adjustable height (via clip) 2.6" body shocks
MRA59-A710 - Monotube 3-Way Adjustable Remote Resi coilovers
Front Strut Mounts
SC59-012 - Pair of new OEM style strut mounts with new bushings and washers (works with OEM struts, Dobinsons twin tube and IMS)
Front Diff Drop Kit
DD59-530K - For 3"+ front lift, reduces angle on CV joints
Rear Shocks
GS59-711 - Twin Tube Nitrogas shocks, 2" body, suits 0-2.5" lift heights
IMS59-60711 - IMS Monotube rear shocks, 2.6" body for 0-2.5" lift heights
MRA59-A711 - 3-Way Adjustable Remote Resi Monotube 2.6" body shocks for 0-2.5" lift heights
Rear Leaf Springs
L59-120-R – 4 + 2 Leaves, Raised Height (55mm, 2.25″ Lift) Heavy Duty for stock to medium loads
L59-121-R – 5 + 2 Leaves, Raised Height (55mm, 2.25″ Lift) Heavy Duty for heavy constant loads (300-770LBS+)
L59-122-R - 5 + 2 Leaves, Raised Height (55mm, 2.25" Lift) Super Heavy Duty for 1000LBS+ heavy constant load (truck camper, etc)
Rear Quick Ride Kit (blocks & u-bolts), instead of leaf packs
QR59-551K - Quick Ride Kit, 2" (50mm) lift blocks with caster correction built in and correct length u-bolts
QR59-552K - Quick Ride Kit, 1.2" (30mm) lift blocks with caster correction built in and correct length u-bolts (new in 2020)
Rear U-bolts
UB59-437K - Sold as 2 pairs, enough for 1 truck
Rear Greasable pins/bolts and Shackles
SP59-060 - Sold in pairs, designed for fixed end of spring but can be used on shackle end also to add easy greasing
SK59-076 - Greasable Shackle Kit
Leaf Spring Bush Kit
PB59-1102K - Contains all required 6 bushings for both ends of the leaf springs plus the shackle hanger
Every individual item page: Tundra 2nd Gen (2007+) Archives | Exit Offroad
Full kit pages: Full Kits - Tundra 2nd Gen Full Kits
Tundra with 3" front lift and 2" quick ride rear
Both Tundras here have full 2" suspension front and rear with full leaf packs. The silver one is running the heavier packs as it was getting a Four Wheel Camper added to it soon after the install.
Thanks for breaking it all down! I'm looking to buy shocks and struts later this year for my 2nd gen tundra. I was looking into ome, since I used them on my first gen tundra.
How do doinsons compare to ome? I'm pretty sure I saw positive reviews coming from guys using them on their fj60's.
Our twin tube struts and shocks are pretty much always valved on the softer/comfort side of things, whereas the Nitro Sport from OME tend to be firmer. So with theirs you're more likely to feel more bumps and cracks in the road with the firmer valving, whereas the Dobinsons will soak those up better for a nice ride.
Last I checked, ours are much less expensive too than OME.
Just updated the first post, adding in all of the IMS options for the 1st Gen Tundras, and also adding in some other coil options for the 2nd Gens.
Any idea if the MRR 3-ways might be in the works for the 1st gen tundra/sequioa front struts? It’s such a tease to have them available for the rear but not the front…
No, there are no plans for the fronts.
Hey @crikeymike - have you had anybody have issues with the energy suspension "new upper coil isolators" on the 1st Gen Tundra (2000-2006)? Or maybe you haven't sold many of kits for the 1st Gen....?
You may want to reconsider using those energy poly isolators...
I ordered IMS setup from Dobinsons Direct and had been fighting issues with that same new black energy isolator squishing out over the top of the spring. Had it happen twice: first time before I even installed them on the truck (chalked it up perhaps being incorrect assembly by a local shop), second time after 10 mins of driving around my neighborhood (after I sent them back and had Dobinsons assemble them.)
Searched around a bit on FB and amazon reviews and found a handful of folks having this issue.
I reached out to Dobinsons again after the second time and they told me they'd never heard of this happeneing before, *but*, they'd now switched to a different *rubber* isolator.
The folks I saw on FB having issues were switching to the the rubber KYB isolators.
I've had mine switched out for the KYB rubber isolators now for a week and have not seen an issue (ran the truck on a 600 mile roundtrip and it even saw some bumpy offroad dirt during that time.)
You will definitely want to reconsider using the energy poly isolators for the 1st Gen Tundras. I would highly suggest using the KYB rubber isolators.
For reference, my setup is:
2006 Tundra DoubleCab 4x4
Front hidden winch
IMS59-50222 Front Shock
C59-302 coil
IMS59-50940 Rear shock
Wheelers 3-leaf AAL
No, I've never heard of that issue. The poly ones shouldn't be squishing out like that
Just added the MRA rear shocks for the 2nd Gen Tundra to the 1st post. They came into stock about 2 months ago. Still waiting on the front MRA's to come out of production and ship over. (No ETA)
Hey Mike, are there any plans to offer lower front lift options for 2nd gen Tundra? A lot of folks like to stay at/under 2" up front to retain stock UCAs and milder CV angles. Thanks
You can use the Sequoia 1.75" coils to achieve that same lift on a Tundra.
There aren't any plans to make any other coils for it otherwise
I have a 2021 Tundra with stock suspension and will be putting a Four Wheel Camper Hawk on the back with a dry weight of 1300 lbs. Would like the truck to be level and around 2-3" of lift. My question is would the L59-122-R Leaf Springs support the camper weight? Also, if I want the truck level which springs would I select for the front for the full kit?
We spoke on the phone, but yes, those leaf springs were intended for trucks with heavy campers on the back.
3" front lift if you want to level the truck rake out a bit.
Thanks @crikeymike ! Two more follow up questions:
1. Regarding wheel offset requirements with the 2nd gen front MRA shocks, your site says: "Aftermarket wheels with +18 Offset or less REQUIRED to avoid reservoir + hose rubbing at full lock."
I prefer to run numerically higher offset wheels to keep them tucked in. I assume this restriction applies to the reservoir mounting location recommended by Dobs, but surely there are other locations that could avoid this issue? Something like what Dirt KIng has pictured perhaps?
2. Are collapsed and extended lengths available for the 2nd gen Tundra front MRAs?
Thanks! Your customer service is the best.
  • 625mm extended length, 450mm compressed length
Yes, because the tire can hit the resi. Sure, you'd just have to figure out mounting it somewhere else to avoid contact. Also, if you're not running too big of a tire, it may not contact. It's a precaution because if you grab and rip that resi, you're in for a bad day, and a shock rebuild.
Thanks man!!
