- Thread starter
- #21
I really think you should try swapping them out. Take a lot of pictures and let us know if it's worth doing.![]()
That's a shame, what did you use for the replacements? Is there any rubber you haven't done?I did this and had no noticeable change to ride quality. Still have the same vibrations as I ever did despite changing out damn near every piece of rubber.
All oem replacements. The frame side lower control arm bushings are the only ones I’m aware of not doing. Literarily every other mount is changed.That's a shame, what did you use for the replacements? Is there any rubber you haven't done?
That's what I was hoping to hear, what are the other details of your 80? What suspension/tires/gear and how many miles? I'm sure you've thought of it all but there's gotta be an answer!All oem replacements. The frame side lower control arm bushings are the only ones I’m aware of not doing. Literarily every other mount is changed.
Mine is a 100 but it’s a 2006 with 180,000 miles. Currently has dobinsons MTR shocks all around with wild peaks, it also has front a rear bumpers. Mind you, the vibrations I have experienced never changed with any modification. It originally had factory ahc and switched to factory traditional shocks then recently went to the dobinsons. At this point I really don’t like driving it. As much as I love the vehicle overall I get headaches about 15 minutes into driving it.That's what I was hoping to hear, what are the other details of your 80? What suspension/tires/gear and how many miles? I'm sure you've thought of it all but there's gotta be an answer!
Every 100 series I’ve been in rides like this. Some of it is tire related but I’ve been on E rated tires and brand new A/S Michelin Defenders 16” size without a truck load rating, just a standard street tire, makes little difference. As do a lot of the older Toyota SUVs. My LX drove like this at only 8 years old and barely any miles when I got it. We don’t have dry rotting issues up north. All my bushings and mounts look like new. A lot of the issues you read about on this forum are related to heat from the hotter states. Heater Ts, etc none of that stuff is even a problem up north.Has anyone installed new body mounts and felt improvement in ride comfort?
My ride is so harsh, it feels like I'm on the Oregon Trail, seriously. Makes me not want to drive it sometimes. No, you can't have it.
I've gone from E-rated KO2's back to P-rated Cooper Discoverer AT3s. OEM (Tokiko) shocks. Stock torsion bars and rear springs. I've replaced all control arms front and rear, or at least the bushings (front LCAs). New engine and transmission mounts. New front dif mount bushings. Trying to replace all rubber interfaces between the running gear and the body.
Still, every crack in our horrible roads is felt and heard throughout the truck.
I do have sliders, made sure they are not touching the body, but haven't gone as far as taking them off yet.
The only things left I can think of are body mounts, and/or going back to Michelin all-season tires to see if it helps...
After trying all the above, I currently have Dobinsons front and rear shocks, Dobinsons torsion bars, and OME 865 springs. OEM shocks and torsion bars couldn't really handle the added weight up front. I do have Dissent front and rear aluminum bumpers, winch, and Gamiviti rack.
But before trying body mounts, wanted to know if anyone has actually seen improvement.
