Do I need a new radiator?
Boise, Id
I bought a bone stock 1996 Landcruiser recently as a project and will eventually add front and rear bumper with swing outs, lift and tires. This will be my weekend fun vehicle and eventually my sons when he's old enough to drive.
This is a great site and I find myself reading a lot here learning and knowing more than I ever did when had an LX450 for 15 years.
Anyways I'm going through doing basic maintenance before appearance. I usually don't work on my own vehicles but this site has so much information that it's given me the confidence to do my own work.
So I got done changing the gaskets for oil pump, crank seal, water pump and disti o-ring. Everything went smooth except the most difficult was loosening the 4 nuts on the fan.
I wedge a screwdriver between the nuts and had to apply a lot of force to get the nut to budge. In the process on the second nut when it loosen the screwdriver slipped and caused my elbow to break the little hose insert on top of the radiator. I place a screw where it broke to stop the fluid leak while I finish the work.
Question is can I get away fixing this to drive it for awhile and get a new radiator later or do I need a new replacement before it can be driven? TIA
I did the same thing last spring and used it as an excuse to by an HD all metal radiator (CSF 2517). Even if that small tube is nonessential, how will you patch the hole in a manner that will hold the pressure?
To bad you don't live closer, I have a very good, not too used radiator for sale.
Thanks. I'm learning terminology here. Just did a search for sleeving and expoxy radiator. What do you know I found the answer. I'm an electrical engineer by trade and this auto mechanics stuff I'm just learning.
I'm just looking for a temporary fix for now and want to work on other things first on the 80 before digging into replacing the radiator if I can get away with it.
If is the original radiator why not just replace it with a OEM. It is 20 years old already. Coolant system is one of the primary areas that shoud be PM in my opinion. You can still get OEM from some of our venders from just a little more than aftermarket.
Self tapping screw into the rad itself, then a small bolt in the end of the hose with the clamp on the hose. I drove mine like that for a few thousand miles once.
Unfortunately you're not alone, broke mine off the same way and used it as an excuse to put in a new OEM radiator, however there are fixes. Don't let this little set back discourage you from tackling other projects. My last big one was a head gasket and it turned out just fine.
Ran around and got this today.
Will tap and JB weld tomorrow. Will order a new radiator also. I'm thinking OEM. Does any recommend something else?
OEM please !
I had this same failure a couple of months ago, after some moron (who resembles me) sat a batter charger on top of the tube/hose overnight. I agonized over repair vs. system pressure for 2 minutes, then bought a new radiator. I still have the old one; looking for a good home. On a trail, I'd plug it in a heartbeat, but this is my DD. I do not want to be stranded 12 miles from home (I'm not as spry as I used to be).
The radiator replacement is straightforward, but getting these top bracket mount bolts off/on is a true PITA. I finally gave in and removed the headlights. On the plus side, it's a really good opportunity to do the PM on the front end you can't get to with the radiator in the way, like changing belts, hoses, installing new fan nuts ('cause some monkey rounded them off with a screwdriver last time), cleaning and lubricating the alternator and air conditioner adjusting bracket bolts (so you don't lose all the skin on your knuckles, next time), cutting that fan shroud in two pieces, and my personal favorite, installing a right angle petcock so draining the radiator doesn't require pressure washing the lower engine bay/suspension to remove all the coolant.
Se post #2. The CSF is a very well built radiator.
Awesome will look into CSF along witH OEM.
The repair didn't take Mike than 10 minutes. After letting the JB weld all day I topped off the fluid wit Zerex radiator fluid and took the 80 out for a 20 minute drive. Everything looks good so far. This temporary fix will do until I put in the time to replacing it with a new one.
