Do I need a new alternator?
West of the Pecos
Hey guys, my '92 (with 3FE) drove around fine the last few days, then when I got in it this evening the battery was dead. Jumped it, let it idle for a few minutes and noticed that as I revved the engine, the headlights dimmed and the needle didn't rise the way it normally does, so I assume the alternator is not charging... Shifted into reverse and the engine died... turned the key and got nothing but a few clicks - engine didn't try to turn over at all.
The battery is an Interstate that I bought in Aug '09, so I'm assuming I need a new alternator. Is there any other likely problem that I should be aware of? Also, is a rebuilt alternator from NAPA "good enough" or is there a better alternative that will get me back on the road reasonably quickly without breaking the bank?
Thanks in advance!
Usually you get the lights when your alt. starts to go. A bunch of the dash lights go on, can't remember which ones exactly, but its like three or four different lights. Did you notice this?
I would say jump it again, if you can, and check to see what the voltage is at the battery. If its not above 13 volts, its probably your alt. Check the ground and connections as well.
My alt is 18 years old, and has been giving me the lights for almost 2 years now, not in the last 4 months though. I would stick with an OEM alternator for this reason. It may be twice as much as some, but lasts 3 times as long.
Thanks in advance!
If you're looking to save money you could rebuild the alternator yourself by replacing the brushes & bearings. Or you could take a risk and get a used one.
A re-manufactured alternator would be good, you could probably get them from Toyota if you wanted. You'll have to pay a core charge. To be honest, it seems all 'new' alternators are re-manufactured units...
You can shop around where you live to see if anyone rebuilds alternators.
If you use a replacement alternator, make sure the RF filter is on it or you'll hear a high pitched whine in your radio that will increase in frequency as the engine RPMs go up.
I would say jump it again, if you can, and check to see what the voltage is at the battery. If its not above 13 volts, its probably your alt. Check the ground and connections as well...
Do you mean some kind of warning lights on the instrument panel? I don't know... I don't remember anything unusual.
Since the battery is fairly new, all the connections were the first thing I checked. All tight, no corrosion, etc.
I'm pretty sure it's the alternator. I've been half expecting it to go out - after all, the thing is 18 years old. I just wanted to make sure whether or not there was likelihood that this was a voltage regulator or something else that replacing the alternator wouldn't fix.
If you're looking to save money you could rebuild the alternator yourself by replacing the brushes & bearings. Or you could take a risk and get a used one...
Any idea how much trouble that is? I've swapped alternators before, but never tried to open one up.
Hmm... I might try to score a rebuilt one from NAPA for a quick fix, and then get some new guts from Toyota and rebuild this one myself.
cheapest solution is to rebuild your alternator. it is quite simple and a half day job if you could get parts. usually its just the brushes wearing out or a bad ic voltage regulator. just replace these parts if found faulty. in worse cases, it may be shorted or grounded windings. my alternator had a weird issue. the sliprings got worn instead of the brushes. i took some shots of my alternator and its parts just to inspire you to restore yours:beer:
replace or grease bearings while at it too.
Very cool, PHIL O.
That doesn't look all that complex... Easier than the birf & front axle deal I did a couple of years ago anyway! ...but... There doesn't happen to be a "how to" thread around here, does there? :hhmm:
One problem I have is that the nearest auto parts store is about 60 miles away, and the nearest Toyota dealer is about 120 miles away. C'Dan is where I generally get parts, and that takes the better part of a week in a best case scenario.
My lights never showed when my alternator went out. However, I'm not sure if you can rebuild the 80 amp externally fanned alt for the 3FE. That looks like the 90 amp internally fanned one. Don't ask me why, but I seem to remember from the searches that you couldn't. Who knows though. If you can't afford OEM (best option), you could always do an autozone alternator. They say they don't last as long, but you get some deal where as long as you own the vehicle, just bring it in if it dies and they give you a new one for free. Also, if you want to upgrade to the 90 amp, then you can buy the bracket off cruiser parts. net or whatever and swap that out with the other one. The 90 amp from autozone is actually cheaper than the 80 amp. Or at least it was in KS. Anyway, hope you figure it out.
You're right PookieBear, mine is the 80 amp one with external fan. I looked at it this morning and noticed that the one that's in there is actually a remanufactured Denso... not sure I want to try "remanufacturing" it myself, though.
Anyway, NAPA lists a "Premium" remanufactured one on their website for $179 with what looks like a good warranty, but the only NAPA within 100 miles of me is not answering the phone today. I'll probably give up on a "quick fix" and give cruiserdan a call and see what he can do for me.
I looked into this a few months ago. Parts to rebuild the one on my shelf would have bought 3 reman units from Toyota. Depends what parts you need I suppose.
I just heard back from cruiserdan. jonheld is right - Dan said that the brush thingamajigs are part of the rectifier doohicky, so it costs the same or more to buy a rectifier as it would to just buy a "remanufactured" alternator from Toyota... not to mention the fact that I don't really know what the heck a rectifier is. :eek:
Hopefully, swapping the whole alternator will solve my problem and I'll be rolling again by next weekend.
Yeah, its not too bad. I've got it down to about forty five minutes or so. And save yourself the hassle, just remove the smog pump right off the bat. Makes everything SO much easier. :). Good luck sir.
"Smog pump" must be that thing right above the alternator, huh? I was wondering how the hell I was gonna get the alternator out from under that thing without taking it out.
Any tips on removing the smog pump? Any tricks to make it "easy"? Doesn't look like it would be all that tricky, but I thought that before I replaced the radiator too... and then got educated about the "easy way to do it" after about 8 hours of cussin', and a few bloody knuckles. You know how it is: AFTER you finish the job you think "Hmm, if I'd have done it this way, it would have only taken about an hour!" :idea:
So I just looked at my alt. too, and its the external fan, 80 amp one, will call it outy for short. When I bought my remanufactured one from the dealer(with my sweet discount), he said I wanted the 90 amp upgrade, and I said sounds good. We'll call this one inny for short, since the fan is inside the housing.
Can I just swap out my outy for the inny I have, or do I have to get a different bracket as well? And does the inny have a rectifyer or not? I hope not, it sounds bad and I would like to rebuild it if it ever went south.:D
Thanks
Not sure about the innard specifics, but I think you have to swap the bracket that is mounted to the engine block. If I remember correctly it is about $25 from cruiserparts.net...
Toyota Land Cruiser FJ80, FZJ80 and Lexus LX450 Parts For Sale
Drop about 7/8's of the way down to the alternator section and you will see they have the 80 amp or 90 amp available. The 90 amp requires an additional bracket that they say is available for... $25. :). Alternatively, some have used the 90 amp with the stock 80 amp bracket by grinding off some of the mounting "ear."
(Oddly, a link started by me...) https://forum.ih8mud.com/80-series-tech/284968-help-3fe-electrical-problems.html
Check post number 15 and 16. That will talk about grinding the 90 amp alternator to fit the 80 amp bracket. Probably easier to spend $25 on the 90 amp bracket though if you upgrade. Later, Michael.
Thanks Michael, followed your thread and links, compared pics to my 90 amp, and think I'll go for the grinding option since I'm poorer than dirt right now, if dirt even has money. Now I just sit back and wait, maybe someday that outy will stop working, its had 18 hard years on it:cheers:
Done!
Got my "new" alternator Friday p.m. from cruiserdan, and my 6-yr old and I swapped it yesterday. Took about 2 hours. Not rocket surgery, but not as simple as pulling the plug and unbolting two bolts. VERY valuable tip on getting that air pump out of the way first thing!
Gauge says it's charging at about 14 volts whether it's revving or idling (spec is 13.8 - 14.4) . My old alternator must have been sickly for quite some time because one of the "normal" noises under the hood is gone now, and I remember the needle on the alt gauge never going above the halfway mark before... and if I remember right, you could watch the needle go up as you revved the engine.
Anyway, thanks again for the tips guys!
I love this site! Makes it where even I can do a bit of mechanicking without screwing things up!
I joined this thread late, but I just wanted to comment that this is a CLASSIC symptom of a burned out diode. There are three in the rectifier - they convert the sine wave ac output to a more-or-less steady (pulsating) dc current. When one diode burns out, you lose much of the current, and you see this mostly at low rpm.
Thus you can watch the needle go up and down as you are driving around town, and it's steady on the highway.
A good alternator normally should show a rock steady voltmeter needle unless you lay a real load on it like offroad lights or a winch, in which case you are exceeding the max rating of the alternator, and the voltage drops.
John Davies
Spokane WA
