Dizzy and Vac advance advice
coastal empire
First... IT IS ALIVE.
Perhaps I need to do a little more reading but I'd thought I throw this question out there...
Got my timing right but to do this I had to turn the dizzy pretty far ccw. Now how the heck do get my vac advance line in there?
As Jetboy said, you definitely have the dissy in on the wrong tooth. You'll
have to pull the dissy and reinstall it again. Be VERY CAREFUL to watch you
oil pressure while you are doing this. If you do not have the dissy all the
way in, you will have zero oil pressure. I'm not sure that you have to move
the plug wires. They are probably fine. Search here for the procedure for
installing the dissy. As I remember, the rotor needs to be pointing between
cylinders 3 and 4 when you drop it in -- with the #1 cylinder at TDC.
Is this right gang?
Had the same issue with mine, could barely make 7* BTDC with the diaphragm hitting the oil filter, and wanted a few more degrees to play with. Had to pull the dizz and rotate it a tooth or two then reinstall it. Can't quite remember which way... Key is to have the rotor initially pointed between #3 and #4 (or so), and the oil pump slot lined up properly so it all seats down right. You'll know when it's right, and when its seated, the rotor shouldpoint right at #1 post on the cap. Should fore right up, unless you got it 180* off...
nial
PH just taught me something. THANKS. Could one also rotate the dissy 60 degrees CW and
then jump the plug wires 60 degrees CCW?
Also, Trekker, do you have the small diameter steel line that you will need to hook
the vacuum advance up? I believe I found some at McMaster Carr that worked.
Otherwise, you'll have to convert to rubber vacuum line.
ah..........then some poor owner down the road is gonna have fun ;)
Pin_Head said:
You don't have to pull the distributor. Instead, you can just rotate it 120 degrees CW and then moves the plug wires over CCW by two holes.
Pin_Head said:
Do you think anyone would notice?
Only if the towers on the distributor cap are numbered! :flipoff2:
THey are numbered! I carefully gound the number off witn a dremel and then etched in roman numbers the new numbering order. ------- NOT! -------
I did move things over and all is well (room wise) for now. I am using the original steel tubing for vac advance.
I got thing running... timing, and idle... BUT when out for a test drive, it runs real good DOWNHILL but when under strain it -the engine- boggs down to the point where I can't get anywhere. Bummer. I'm gonna hit the board and books to find out why right now but if anybody could point me to where I should look that would be cool. Here's what I've done so far:
1. Timing correct
2. Set idle but ear but will hook up vacuum gage next.
3. Revs really nice when sitting still and not under engine load
4. Plugged up all the holes (4WD vac assist, PCV, and the two tubes coming out of the 1bbl to manifold adapter)
5. Brakes and parking brake are all good so I'm not dragging a wheel or anything.
On a side note, Mark I mentioned that I was going to send you my carb for a rebuild but I'm gonna hold off for a few. I found my major problen (clogged jet) and now fuel is getting where it's supposed to go. :) I just want to drive this rig around the block for :crybaby: out loud!!!!!
yup......that would be me, I like OEM parts and the OEM cap is #'d.........I would end up pulling out what little hair I had left :D
I went thru this on my 45LV with a SBC in it.....seems someone moved the cap and not the dizzy.........
