DIY/Poor Man's Floppy Mirror Fix
Holly Springs, NC
11 years ago I fixed my driver's side floppy mirror by cutting two new slots 90* out from the original slots.
I never liked the c-clip fastener and knew that it would eventually ail. Today was that day.
While @Delta VS has the perfect solution, I just placed an order for their panhard/steering box reinforcement kit and couldn't justify paying for another shipping cost.
Tearing into the mirror again.
Disassemble. Take a photo of the wires before you pull them out.
Take out the four screws from the mirror frame. There's a fifth screw at the hinge. Rotate the mirror around to find it.
Carefully remove the casing from the mirror. When you lift the mirror frame off the post, be sure you don't lose the 3 ball bearings underneath. I applied grease to hold them in place.
Damaged post.
My solution was a copper nail. It's the perfect dimensions and while it will oxidize it won't rust away. I was given a thousand of these nails and have never used them for anything else.
With four sides of the mirror post very thin and warped, I needed more meat for the nail. I went with a 45* angle across the square. I used an 1/8" drill bit.
Test the pin and washer without the spring.
Here's the hard part. I put a block underneath the mirror mount but I couldn't simply place a block on top to squeeze the spring down. I used two scrap blocks and spaced them the width of the post. This was extremely sketchy but worked and I was able to install the pin.
Pin installed. I tested the mirror for functionality.
Reinstall the plastic cover. Don't forget your Solvefunction @Outsane shakey mirror fix.
Nice write up! I dig the old clamp too…
