DIY EIMKeith RAM Install
Grand Junction, CO
So, I haven't done many DIY tutorials, but I haven't seen a great install for the EIMKeith RAM brackets, so I thought I would contribute:
Things you need:
1. Welder, if you don't have one, then go buy one and teach yourself to weld, this is invaluable. I have a basic HF 120 V MIG.
2. Grinder was helpful. I have three grinders, Corded 4.5", Corded 7", and a cordless 4.5". I used a 7" cutoff wheel and a flap disc.
3. Basic hand tools, 24mm socket for Radius Arm frame bolts and 22mm for the axle mounts. I use a cordless impact to make my life easy.
4: Torque wrench 1/2 or 3/4 for tightening things up at the end.
First thing that was not obvious to me: the brackets are specific to the left and right hand mounts. They do not quite fit correctly if they are swapped. So make sure you're putting the right one on the right side. It should sit flush when on the correct side and in the correct position:
Next: these need to be installed co-planar to the existing mounts, and the new mount needs to maintain the same width while welding. This is the hard part as when you weld, things can easily get distorted and your bushing no longer fits in the mount. EIMKeith recommends using an old bushing to maintain the width. I didn't replace the bushings, so I decided to make a spacer. Start by measuring the width of the bushing;
Then make a spacer of the same width:
I used my 7 inch cutoff wheel, my vice, and a spare chunk of thick scrap metal. I did make it rather wide so that it would help me to maintain co-planar geometry:
This will now keep the leaves of the new mount parallel and with the same spacing as the stock mount, and it will keep it from distorting while welding.
In preparation for welding, you need to cleanup the mount with your angle grinder and flap disc, making sure all surfaces you are welding are clean.
Mock it up with your spacer which keeps it coplanar, and tack weld it in
I tack welded it at the four corners to prevent distortion, then bead welded it:
Note that this is not my best welding work as I'm laying down welding something under the car. I didn't prep and clean all of the metal as well as I should have, and it took me a minute to get my settings and technique right on welding two metals that are not the same thickness.
I then used my winch and jack to get the radius arm back into position. Reinstalling the Radius arms isn't that easy, but I think there are some other tutorials on that.
IMHO, these are better than caster plates as you can easily go back to stock. Caster plate require you to cut the axle mount for the radius arm and weld a plate. The EIMkeith RAM mounts allow access to the stock mount hole if you ever upgrade to something like the Hyper or superflex arms:
upload_2016-9-2_0-52-39-jpeg.1315441
Nice job dude, thanks for taking the time to write this up.
Just as a FYI to others, please don't turn the flanged hardware when it comes to your suspension. The flanged nut or bolt has four serrated dimples that bite into the metal and by putting your socket/wrench on this hardware and turning them will cause the serration to become less prominent, which in turn causes them lose their torque over time. FSM clearly shows this but I wanted to remind everyone.
Getting ready to add these to mine and have a quick question. I saw a recent post where someone added a 1" spacer at the pinion flange since the mounts move the axle forward a bit. I'm running a DC shaft and curious if anyone has had an issue not using the spacer. I didn't think it was needed....
I don't think it was needed. I don't have a spacer on my front shaft but I am also part time.
Does your dc shaft have a slip joint? If it does than you should be good.
Yep I was reading that one as well so I figured I didn't need it. Yes my DC has a slip joint. It's a LandTank unit.
