distributor replacement (a short story)
Beaverton, Oregon
Website
thatsjet.com
A couple of days ago, my Mallory unilite dizzy decided to throw a bearing, or spring or something... spun the dizzy right out of its socket and pulled all the wires out, even cracked the porcelain on one of the plugs. As replacement was in order my options were:
- Stock vacuum-advance Toyota dizzy: approx $300 (new/rebuilt from Sphinctor off road)
- Another replacement Mallory: approx $350
- D.U.I. HEI from Man-a-fre ($395 + $80 for livewires plug wires)
Well... I went with the D.U.I. expecting only minimal improvement over the Mallory because it was electronic as well, and should be similar in performance. WOW, was I wrong! While I didn't notice massive HP gain (maybe slight) I certainly did notice that it performs absolutely flawless at every point of the power curve. It barely needs choke any more to get started, doesn't cough, sputter, or argue when you stomp on it, and seems to be getting at least a couple of more miles to gallon performance.
So, if you ever thought about replacing your distributor and wondered what to get, my vote is for the D.U.I. I'm pretty sure you won't be sorry.
Jeremy Anderson - California
Hey Jeremy, glad to hear you are so happy with it! We try to promote these as much as possible, as we feel they work better than all other ignition upgrades for the 2f.
The best thing about the perronix kit is the price. The DUI will out-do that kit anytime. Steve
hey miletwo
what carb are you running? do you have your DUI hooked to the carb's vacume port (if it has one).
i have a DUI but have never had great response with it (only mild improvment).
but then i'm running an old rochester 2B with no vacume port.
i'm in the market for a new (used actually) rochester carb WITH a vacume port so i can plug in the DUI.
thanks
CruisinGA said:
Rusman- why not drill your current rochester for ported vacuum?
you can do that?????
send me a link please to some writeup or tech on how to do it.
bump
rusmannx said:
hey miletwo
thanks
The performance of it will definately go up if you hooked up vacuum to it. The D.U.I. has 2 advances, centrifical and vacuum. Right now you are only running one advance that only opens up at certain rpm's, when the vacuum is hooked up you will see a larger power increase accross the whole board. You can drill a carb to get ported vacuum, but you better be careful. Also keep in mind that a drilled out vacuum port will not act the same as a carb with a vacuum port on it already. Factory ports are usually not round, they are graduated, meaning they are more in the shape of a diamond. Steve
maybe i should just look for one WITH the port already on it.
i got my dui last week and must have got a bad one, i installed mine and had no spark. looks like i will have to run the points untill man-a-fre gets more in.
Sorry for the delay... I'm at a conference up in SFO this week. Anyway... I have the stock 2Barrel Aisin and yes, running from the vacuum port. I found that getting the timing right and performance perfect required following the instructions from PerfDist to the letter as follows:
- be sure to pull and plug your vacuum lines (dist/carb).
- Set RPM to 550/600 range (IMPORTANT!)
- Set timing to 12°-15° Advanced
- hook everything back up and set your idle back to wherever you normally like it (I like 800-900rpm)
- TRY IT! Your particular vehicle might sputter a bit with it hammered...if so, advance it some more (it's okay, really)
- For the first day or two I monkeyed with timing a bit to find a sweet spot. The main thing here is to make sure it's advanced enough to accept throttle inputs but not so fast that it gets ahead of itself and goes all Chernobyl on you (a.k.a. overheating)
Let me know if you have any other questions... I'll try to be responsive.
Jeremy Anderson
i got my replacement dui today and put it in. all i can say is WOW. made 100% difference. the weber carb i have been running was rich but now its back to the old blue smoke. the guys at Man-a-Fre helped me out alot thanks
