Distributor help
Pa.
I just finished putting a 79 dist. in my 74 40. Now I can't get it to start!!! I put it in the same way the old one came out. I'm using a Flame Thrower coil and all the wires are hooked up right. The red wire from the dist. to + and the white to -. The rotor is in and the dist. is all the way down. I pulled a plug out and turned it over,but there's no spark at all.It's a rebuild dist. so I think it should be ok.
Any ideas?? Thanks!
I printed out your thread before starting this project. I have no clue why I'm not getting spark. I've tried everything I know.
You didn't mention an igniter of any kind, are you using one or did you hook up the distributor directly to the coil? The igniter is the "switch" that energizes the coil to fire, and the distributor simply tells the igniter when to switch.
You'll need to get an igniter from a fully electronic ignition from a Land Cruiser or mini-truck and wire it up appropriately.
I just got the 79 dist.,and it looks like it has everything I need inside.It's got the signal rotor and a signal generator inside. I had a Pertronix system in before going to the new dist.
I'm not too familiar with Pertronix but I thought that was a Hall-effect setup that mimicked the points and thus required no igniter. Someone else can clarify if I'm wrong here...
The OEM distributor setup uses a variable reluctor setup and requires the igniter. The passing of the signal rotor by the pickup coil generates a positive voltage that switches back to a negative voltage. The switch from positive to negative is what the igniter looks for to send 12v to the coil.
That wording sucked. But you still need an igniter. :D
I think it might be possible to use a regular old GM 4-pin ignition module, if you really want to get it running. I saw a diagram on the web somewhere. Basically you just hook up power, ground, and the distributor wires.
I'm pretty sure this would work. IMO not a great solution, using spade connectors, but I think it would run just fine. Been meaning to try it out for a while.
Thanks again Matt. Dumbass me thought you could just put the new distributor in and go!!! I'm going to see if I can find one.
