Distributor Cap Question
Looking at the photo, if the hose fitting is in the outside of the diaphragm, doesn’t that make it a vacuum advance?
it's where the vacuum pod is located on the distributor base. you want the pod facing the front of the engine for advance
if the pod faces the rear of the engine it is retard.
I’ve always assumed that and my guess is a rearward facing vac pod usually does retard the points plate. I randomly stumbled upon a post by Mark’s Offroad awhile back. Can’t believe I was able to find it again.:confused:
You don't need a PN to determine advance or retard. Form follows function. If the points plate moves counterclockwise when vacuum is applied to the diaphram, it is an advance; if it moves clockwise, it is retard.
And FWIW, just because the daiphram is on the forward side of the dizzy, does NOT mean it will move the plate counterclockwise.
Best
Mark A.
