Distilled Water Flush
Columbia, MO
I've read and read and read...
...and really hate to start another coolant thread but I wanted to run my plan by some of you. I will have a local shop I use do the actual flush since my condo garage isn't the best environment for this. ;)
Unfortunately, my new to me '93 has "brown" coolant in it, so it's hard to tell whether it's run more Toyota Red or Green in it. I want to flush it well because of this, regardless of the type of coolant I go with.
I thought I would run one or two cycles through the system with distilled water myself (with rear heater on) to flush the system fairly well and then take it to the shop for the actual flush, making sure to tell them about the block drain plug and flushing the rear heater core. **EDIT: Is my distilled water "flush" necessary IF the shop does their job correctly?** It appears they did a good job flushing the Dex-Cool out of my Grand Prix earlier this year with their machine.
I want to do what I think is right based on my ridiculous amount of research, have it done, drive it and forget about it for 12 months. If bad things happen down the road, so beit. I tried. ;)
Your thoughts?
Thanks.
--Mark
It is always a good idea to cycle the system with water. This dilutes the remains of coolant and gives you a 'clean start'.
But you will not get rid of radiator sludge if you have it. Probably you will have to replace the radiator. I have also read about people adding some stuff to their cooling system but I don't remember the outcome. Maybe someone else will chime in. Was it baking soda? Was it vinegar or some other mild acid? I don't remember.
Called my shop today and stressed that I wanted the radiator, block and heater cores all flushed and asked if they could do it. I told him it was a '93 Land Cruiser and he immediately mentioned the rear heater and that everything would be back-flushed. That gave me a bit of confidence. I'm taking my own coolant, distilled water and OEM thermostat/gasket/radiator cap.
Hopefully, they get a good flush. After checking more closely tonight, the coolant in the truck by the PO is yellowish, not exactly the brown I was describing. It obviously has been switched over at some point from Toyota Red but at least it is not "sludge brown." Called my local dealer today and they quoted me $29.99/gallon for Red. Crikey!
--Mark
Recently did mine by filling with distilled water, running around for a day, drained and did again the next day. Then on the 3rd day filled with Toyota Red mixture. At $1/gal of water it was more a matter of time and energy than the extra cost but I felt it was worth it. After a couple months of running now the red looks just a bright and clean as when I first put it in ('94 with 160K on it -- although now I'll need to be replacing the radiator for a leaks around the top plastic, not necessarily due to corrosion).
I would not hesitate to drain the thing, fill it up with some water with coolant system cleaner in it (probably just detergents likely) and run it for a few days, assuming you won't see any freezing temps and will keep an eye on the gauge when hot. That might be enough to resuspend some of the deposits, which may then be drained out when you do the real drain before filling.
Ask them to keep a sample of the drained fluid if possible so you can see if there is junk in there.
Does the flushing machine have a tub where you can pour the distilled water in?? I once asked my local dealer if they used distilled water for a flush and they said no, just regular tap water.
Unsure. I asked them to use the distilled water and coolant I brought in and even taped a note to the console detailing how I want things done (I'm sure they'll love that). I can only hope they do the job I'm paying them for. ;)
I'm not a fan of letting other people work on my vehicles (unless I'm there watching them) but didn't have much choice this time.
tap water is fine if it's only left in for a little while.
The stealership around here sells the red gold for $21. If you have another dealership around you, it may be a good idea to call around. They do set their own prices. I have never mail ordered antifreeze but the difference between $60 plus tax, and mail order plus shipping may come out with significant savings. Give CDan a call.
I don't see why it would be really important to do the FLUSH with distilled water as opposed to tap water, unless your tap water is just filthy... When performing my annual coolant flushes, I follow the FAQ here using the Prestone kit: drain block and rad, attach kit, run hose water through for 5 minutes, drain again, fill with AF and distilled water. Sure, I will not get every drop of tap water out of the system, but we have very clean, neutral water in Seattle.
