disconnect swaybar?
Sand Cruiser,
I don't have time this morn for details, but your 'feelings' about sway bars being of limited or no effect on rollover safety is incorrect. They act as dampers to prevent the center of gravity from moving quickly side to side, they literally act as if the outside springs in a curve were getting stiffer as you swerve harder. They're incredibly effective at helping a regular sedan in this situation, even moreso on a high center of gravity vehicle like the 80. Offroad improvement is also over rated.
DougM
yeah, see, I was totally wrong.
Here are some links (aimed at racing, not offroad):
How sway bars work
HowStuffWorks "How do stabilizer bars work?"
In essence: with sway bars, when you compress one side of the vehicle, you apply torque, through the bar, and compress the other side as well, which helps increase spring rate when the vehicle is leaned over in a turn. It also helps add traction to the inside tire, which helps prevent skidding. Obviously, it diminishes offroad performance. But makes a big improvement to on-road, especially emergency performance. I plan to reinstall my front bar this afternoon (heading to the Toyota now to buy bushings for same).
I'd consider quick disconnects up front, perhaps, as it looks very easy to implement. But will run swaybars on-road. Period.
Disclaimer: Toyota put swaybars on the truck to improve... something. I don't advocate modifying anything beyond your blinker fluid, and even then you should try to find some DOT blinker fluid, not that cheap crap from 3rd world countries.
:whoops: Should I be changing my blinker fluid???!!! My truck has 204K miles and I don't know if it has ever been changed! Could not find a spec for it, what grade should I use and is synthetic recommended?, it is accessed through the sway bar?
:hillbilly:
:hillbilly:
Yes, you access it through the sway bar. It only comes in 1 grade, through Toyota, and if you don't use synthetic you're a dork. I recomment adding a zerk (grease fitting) so it can be changed more easily. Of course if you've removed your sway bar then you're screwed!!!
:lol:
My understanding is this, and you geniuses with degrees can correct me if I'm wrong: The purpose of sway bars, often referred to as anti-roll bars is to aid in the control of the vehicle, not prevent or help prevent it from rolling. Although, anti-"body roll" or anti-wallow is a desirable effect, it is not the real purpose of the device. Maintaining vehicle control in quick direction changes is the design function. Although, a rig with a higher center of gravity (CG) will probably see a more dramatic advantage, as Doug mentioned. In a scene where a rig has retained traction on a corner and is in jeopardy of rolling the vehicle, the sway bars are not the determining factor, the CG is. The main advantage of sway bars is to help the properly trained driver to maintain control of the vehicle in every conceivable situation. Each vehicle's sway bars are tuned by the manufacturer, to have the best understeer - oversteer effect. They are there to help the driver, with secondary benefits being less wallow or body roll.
With that said, the comments made on different posts in this thread make more sense and hopefully people will realize that the benefits out weigh the drawbacks to run them at all times on pavement.
No! Dear God, No! Don't ever get blinker fluid on ANY of the suspension components or it'll make them intermittent components.... all sorts of oscillations. Be very careful! Especially that synthetic stuff!!
:hillbilly:
back to sway bars: can someone explain "understeer" and "oversteer" to me? I don't think I understand the terms correctly.
I agree completely with what has been said above by all.
By no means was I telling folks not to run sway bars.
I was merely stating the handling characteristics that I have experienced with mine removed for now.
I am still testing with or without and disconnects and maybe even other types of sway bar applications such as torsion sway systems with disconnects.
I am also in the process of evaluating the entire front suspension set up of my 80.
I have been doing extensive research on other suspension applications and their handling characteristics on and off road.
I like to know how my rig handles with all types of suspension applications regardless, because that is what keeps the rubber side down.
For me it is all about what I should and should not do and what the rig can and can not do effectively while trying to achieve a balance between all of it and have a rig that performs great on and off road.
Which the 80 for the most part already does.
But, I think that there is room for improvement over the current design and still maintain a safe handling vehicle.
The million dollar question is at what cost will the improvements or modification come?
Understeer is when you slide off the road frontwards. Oversteer is when you go off the road backwards.
Most factory setups are inclined to Understeer because it's easier for most drivers to handle. Removing sway bars can have a dramatic effect on this characteristic of handling.
Oversteer is when your vehicle steers more than desired. Understeer is when your vehicle steers less than desired. Dukes of Hazard style driving would be considered oversteer. Understeer is when you turn the wheels more, but don't steer anymore. Typically, cornering understeer happens when the front wheels are skidding and oversteer happens when the rear wheels are skidding.
Big picture explanation (not much detail):
Understeer - When you turn steering wheels, (whole) vehicle tends to continue straight or not follow path driver intended.
Oversteer - Vehicle initially follows steering wheels direction, but the rear of vehicle (only) wants to continue in the original direction.
I have been running without sway bars for well over 5 years now. I've gotten very used to the handling and have accommodated my driving to take into account not having sway bars.
That said, I will say that I think not having sway bars played an important part when I rolled my truck in February of 2007.
Do you think having sway bars would have eliminated the roll completely, or just lessened it?
Those who say running off road without swaybars makes only minor improvements need to go off road in a heavily modded 80 more often. On every run I've been on, with and without the club, someone has commented on how well my 80's suspension articulates, and I believe it is night and day, just like street tire pressure vs. letting air out for the trail. With nearly 6.5" lift in the rear and 3" lowered bumpstops, I can make my 35's rub all over.
It is not fun ripping a sway bar bracket off the top of the front axle, taking out the brake line with it, then having to drive home from the trail with a malfunctioing brake system.
Shearing off the bolts that hold the rear link brackets to the frame also cause major trail conjestion.
If one is running a 4-6" lift, the vehicle is flat-out going to handle emergency maneuvers differently with or without sway bars intact.
I have chosen to drive my now daily driven 80, 6" of lift, with 4 year-old in back with at least a front sway bar now, not over 65 miles per hour, and mostly 60 at that.
im thinking about pulling my swaybars. snapping the rear bolts to the axle kinda helps push me towards running without. drilling the busted bolts out and adding swaybar drop brackets just seems like more of a hassle.
for the front, what did you guys do with the lines that were attached to the swaybars? IIRC they're just ABS wiring? are there actualy hydraulic brake lines that are tethered to the swaybars?
Nissan Safari/Patrols have an optional remote mechanical front swaybar disconnect. Could the hardware be adapted to a LC? You simply pull a handle under the dash to disconnect, then release the handle and drive a bit to reconnect.
I believe they are the abs wiring, locker wiring and vent on the right and the left abs wiring. Just bundle them and make sure they have enough stretch and don't catch on anything when the suspension is drooping.
I am glad you posted this, Doug! I, too, feel very strongly the same as you and would like to add my support to the points you made. One thing people quite often forget is how comfortable and spoiled we get and ignore the safety designed in to our rigs. Yes, our rigs will handle some off road maneuvers better with out the sway bars. It's human nature to take short cuts and delude ourselves into believing we are not sacrificing anything by just leaving them off. The biggest problem, and one that is off most people's "radar screens", is that the future is not predictable. Even for those who have temporarily disco'd sway bars, who knows what will happen even on that seemingly short drive from the trail's end to home? We need to keep in mind that the most dangerous place that our rigs will be traveling is the paved public roads and highways. This is where we want our vehicle to perform best and safest. Food for thought!
'94 FZJ80 w/220K+miles; FF & Disc Brake Rear Axle, ARB w/Ramsey8K, Kaymar w/spare pivot, "Redneck Enginuitive Bellypan" skid plate, 2 batts. & isolator, OME 850/863 Springs w/OME N73/N74 Nitro Shocks, SS Brakelines, OME caster kit & steering damper, CDL W/Pin 7 mod., Temp.gauge mod, Amsoil converted, F.O.R. sliders soon. Green Diamond Tires: Icelander M/T LT265/75R16-E - Tom - The battle to defeat neglect is won or lost here and now.
Interesting perspective: Lifted, non-OEM front bumper with a winch, tons of extra weight, non-OEM brake lines, retread tires. It frightens me to think of a vehicle like this driving near me or my wife.
[/FONT][/SIZE][/COLOR]
What kind of reply do you want? Do you really believe that your vehicle is any safer than mine?
Your rig: Oversize tires, a year younger with more milage, lifted, modified and unproven suspension and the icing on the cake: no sway bars. Cmon, man!
