disc brake conversion 69 FJ40
Tucson
I am finally going to do this after 25 years of messing with drums, and single reservoir master cylinder.
I sent the following email to SOR tech, and got a nebulous answer with no good advice
"I am running an early 69 FJ40, but with a 72 tub. The brake system is the 9mm one with the three bolt single reservoir master cylinder. I fabricated an adapter plate for the firewall to handle the three bolt one. The brake pedal assembly in the cab is 72.
I am getting ready to do a front disc brake conversion, and want to replace all the old brake lines with 10mm. NAPA sells a 9mm-10mm adapter, so for the mean time I can keep the old rear wheel cylinders, though eventually upgrade them to 10mm as needed (probably sooner than later).
My question is, which one of your brake line kits should I order? And, is there anything I have forgotten to ask, or tell you? Or something else I need to order to go along with it?
I have not yet decided between the MAF conversion kit or JT Outfitters, but from what I can tell, the brake line system should be the same."
I don't want to have to make my own brake lines, as the conversion itself will take time, so if I can buy one of their kits and minimize my own bending and modification, I would prefer that.
Any thoughts or advice as to which one? I think I can get by with the one for 71-75, and just block off one of the outlets on the T-fitting on the passenger side, as the replacements can't be found anymore.
Nothing against SOR, but I purchased my upgrade from Man-A-Fre. I got the new (non-power) dual Master Cylinder, and the front disc kit. I also purchased a flaring tool from Eastwood (@ $199 - not cheap, but made the process so much easier and faster). I also ended up purchasing additional 10mm nuts and flared even more. Doing the brake lines in pieces made it easy. Afterwards, I purchased and installed the rear. The kits were fairly straightforward I was able to accomplish them over a weekend.
First off, I'd not use a JT Outfitters kit... your life will depend on it.
MAF... at least a safe option, but it uses inferior drum brake hubs which are smaller.
I used all Toyota disc brake parts, and have had amazing results. The first brake job lasted 95,000 miles and 19 years. They were still operational, but I felt it was time... before they stopped working and caused a problem... did I mention 19 years without a brake job. To boot, I'd rebuilt them in the garage, replaced all the rubber, and only replaced the pistons I had to. Hey, I was broke and they were $10 each... 4 had to be replaced, and 4 didn't have any pitting in areas that mattered. I won't complain when the fast wearing pads last 19 years. BTW, get soft pads so the calipers don't freeze up from lack of movement and spend $20 every 10-15 years to replace them.
I'd make my own lines or spend a few bucks on ready made lines from a local supplier... That said, 71-75 lines should do the job. 76 lines moved the flex line to the passenger (right) side of the front axle. Mine had them on the drivers side (1974).
I'd also mount a dual master cylinder and ditch the single system. Personally I'd also run a booster, but others haven't so it's up to you. For me, the writing is on the wall, and I need all the power assist I can or I'll have to give up driving it.
I also did a 69 front disc conversion with dual master from mana fre and disc from jt outfitters. I would also avoid the jt outfitters kit. The calipers are just off of a monte carlo, I think. I don't know how you found 9mm to 10mm fitting adapters, I looked all over including napa. I think I found they quit making them 15 years ago, I might be wrong.
If I had to do it again I might consider a front axle swap. I blocked off the T-fitting on the passenger side like you said. If you can't find an adapter, try to salvage the 9mm fittings to the rear and flare a new line through them. I spliced into the existing lines at the junction fitting on the frame below the fuse box. Not the safest using the old lines, but I didn't/don't have the time or funds, and I plan on doing a better job later. I think you also might need a proportioning valve and disc and drum residual valves. You might want to go with a later toyota model mc instead, one that came off a model with front disc and rear drum.
When doing the front end, I also looked for 9mm to 10mm adapters and found none. When I removed the old brake lines, I ether reused the old fittings or used the new enclosed fittings (from the MAF kit) (with the new flaring tool) when making the new lines. I was even lucky enough to find additional 9mm fittings at MAF and bought some of theirs. Making the new lines was intimidating at first, but it went a lot easier than I expected.
With that flaring tool you got I bet it was easy. The cheap one autozone makes it slightly less fun. I'm considering getting the $200 flaring tool
I also did a disc conversion on my 69. I went with MAF. Kept the original axles front and rear. Had to do little grinding up front , but was easy. The rear was a little difficult, but not to hard. Buy a good quality flairing tool, make sure that the 1/4 inch slot is in the middle of the tool makes it easier to flair. There is no adapter from 9 to 10 mm. Replace your lines don't be cheap your life depends on them. I had no issues making my own, just takes a little bit of practice. I also went with MAF no booster master.
I have 8 of the 9mm - 10mm adapters I bought at the local NAPA store about 6 years ago (someone said they don't carry them anymore, but I found them on a google search earlier today, so someone still makes them) but since my first post earlier today, I have decided to go with disc both front and rear, so no adapters will be needed
I called NAPA this morning. They no longer carry the 9mm-10mm adapter. However, they referred me to Pirtek, and they carry them. The Pirtek guy told me that they are actually manufactured by a company called brakequip.
Wow, Harsh!. I went with JT Outfitters 5+ years ago! Best upgrade I ever did! No weak link I found, front and back. Did it myself and I'm a Non pro, Half ass but do it right mechanic. Monte Carlo Disks, I, just like you, had enough of all that Drum brake crap. Bought the new brake master cylinder too from JT, Did I miss something? It was very solid conversion that has been excellent, I even bypassed my Power brake vacuum booster, I'm totally manual brakes and I'm liking it.
Brakes are an area where the best option should be used. If my antenna breaks no one will die... brakes not so much. I've seen photos here on mud of broken JT Outfitters disc caliper brackets... and why? Why use a weaker product when a far superior setup is available using factory 4 piston calipers?
You'll not regret using stock Toyota parts. Also, no one wil be sued for using a welded together part if you're in an accident, if you use the far superior stock parts.
I have read all the FAQ's and the threads dealing with the 9mm - 10mm brake line conversions. I know about the 9mm - 3/16 24 adapter, and Pertek actually has the 9mm-10mm adapter.
However, I have found nowhere where someone just took a 10mm X 1.0 tap and re-threaded the t fittings and junctions, as those are the only real problem to find in 10mm.
Any thoughts?
Any thoughts?
I am curious..., have you tried this option of re-threading the t-fittings?
I tried several times and could not get a good seal. I think it was partially because the 10mm tap was not the right one to deal with the flair issue coming from the brake line.
I ended up running all new brake lines and then scouring every salvage yard in Tucson looking for the 10mm T's and other junctions necessary to the system.
Agreed, and find a mini truck/4Runner axle or fj60 front for the knuckles and birfs. My 69 has the mini truck setup. My daughters 72 has the fj60 Parts with vented rotors and bigger 92 4Runner calipers. All Yota parts that bolt together and use the 10mm fittings and better knuckles. Lots of info in the FAQ section.
