Disasembly the Birfs for cleaning
Albany, NY
Finally tonight I got around to clean the birfs.
The FSM page SA-16 says:
--- Start FSM
5. INSPECT BIRFIELD JOINT INNER PARTS
(a) Hold the inner shaft in a vise.
(b) Place a brass bar against the joint inner race and remove
the outer shaft.
(c) Tilt the inner race and cage and take out the bearing balls
one by one.
(d) Fit the 2 large openings in the cage against the protruding
parts of the outer shaft and remove the cage and inner
race.
(e) Remove the inner race from the cage though the large
opening.
(f) Clean and inspect the joint parts for wear or damage
--- end FSM
I wanted the take the inner shaft apart from the outer shaft so I can take the birf apart and clean it. But I was unable to figure out how to do it.
Here is the picture from the FSM how you suppose to do it. I gave it a few wackes with a brass hammer. But when nothing moved I did not want to continue.
Go to the hardware store and get a piece of 2" black pipe that is at least 3-4" longer than the inner axle shaft. Slide this over the shaft, stuff a rag in the open end. Slam it open end down on a block of wood on the floor, you don't have to do it very hard. Make sure you hold onto the birf while you slam it down. Make sure you get new snap-rings that go on the end of the shaft inside the birf, the old ones will be trashed.
Or pvc pipe. (https://forum.ih8mud.com/80-series-tech/164895-how-remove-old-birf-axle.html#post2319253)
yes, i used pvc and it worked like a charm.
Well, on the way out the door today I had to tried the FSM method.
I put the outer shaft in a vise, and hit with a brass drift where the FSM shows you and it came a part.
I had to whack it pretty good, so with the information you guys gave me I knew that whacking it is the way to go. So I whacked it a bit harder and also turned it a bit every few whacks. Finlay it came a part.
Many thanks.
You should still get new clips ordered and installed. :cheers:
