I seen most of the 80-s overseas had installed the single coil or direct ignition coil.Does anyone of you guys know whether those gives you more power? or any advantage from it? Thank you
Rich said:The biggest benefit is that it eliminates the need for a distributor and rotor. The three coil system works by firing two cylinders simulataneously, with one cylinder being on the compression stroke, and one being on the exhaust stroke. No benefit to firing on the exhaust stroke, it is just that this scheme minimizes the number of coils required to 3.
