Anyone know where the proper location is for a 12/73 dimmer switch is? ive read floor mounted switches change data in 72, but my dash switch doesn't appear to have a dimmer. Maybe PO replaced dash switch with an older unit?
I’m pretty sure that a 12/73 should be the turn signal lever, push it forward or backwards.
Push forward lock the brights. Believe it was a few years later could pull back and flash the brights even if highlights are off. Would return to center once you release. Could be the 74 model when it started but would need to research more.
My 74 doesn’t return to center if you pull back. Back is low, forward is high. That’s my only option.
