Differential cover/skid plates
Who makes good diff covers/skid plates? I need to buy some but I'd like to get some input from the people who are using them before I decide. Any pics and info will be helpful. Thanks
Check out iron pig off-road's website. Too dark and rainy to snap a pic now but can get one later if you still need the visual.
Can't say enough good about Bump It Off Road's skid plate. I have had mine for about a year and have hit it HARD several times- never moved, no damage. Good coverage, good pricing, and Mike is great to deal with to boot. What else could you ask for?:D
Slee baby!!! http://www.sleeoffroad.com/products/80_skidplates.htm
For front differential protection I have found that 3/16 plate welded to the bottoms of the diff housing with a wrap up along the ring gear bump is all that is needed. The axle housings are a fairly soft metal and if you "diff surf" over rocks frequently they will wear down. The additional plate wrap will add extra rigidity to the front of the housing in the event of an impact. Some folks also use an 8" pipe cap custom cut and welded on.
For the rear, just a plate on the bottom should be sufficient.
I have IPOR belly plates on both my 80s and IMO you won't find lower profile/better protection. The mounting hardware will need to be replaced periodically as the bolt heads tend to be vulnerable, but it offers very robust impact protection for expensive parts and allows the truck to slide over those pesky rock points.
You'll also want to address the rear trailing arms as they are small and will bend.
The rear driveshaft is also vulnerable and loose the rear swaybar.
The stock exhaust system on the later 80s is just plain stupid for rock crawling. You can replace the downpipes/cat with a Magnaflow unit which will give you a single horizontal cat and allow a shop to rework the crossover to above the frame, keeping the large stock muffler and positioning the leading edge higher than stock. The rest can be reworked to exit behind the right tire land level with the frame.
Doing this clears out the entire right side of the truck and will prevent further damage.
IPOR skid. Very strong! I utilize it every time I wheel.
Trail gear makes a font diff cover. Just needs to be cut down a little to clear panhard bar. Only $35. Stout for a trail gear product.
Any aftermarket rear control arms are stronger. I have metal tech adjustables. Landtank makes some really nice ones too.
For rear drive shaft I made some sliders from frame to rear control arms mount. I have destroyed one drive shaft prior. It's not fool proof but does help in certain situations.
Nice. I've been thinking about doing something similar for years. Never got around to it. I always seem to find those pesky lower arm hangers and they get beat up over time.
Same here. But after a day on trail and a close call on my drive shaft (brand new oem) I got right on it. Was very easy. Few hours. Few ft. Of 2x2 1/4" wall.
It probably does hang lower than some of the others, but I like that it is a full cover plate. The belly plate is a lot different than the other xfer case plate Slee makes.
As for RCA's - many weld either angle iron on bottom, or sleeve with tube clamshelled & each half welded over top of factory - either way, saves buying off-the-shelf
FR diff armor - Just Differentials carried some lower half units that were quite affordable - but that was 2-3 yrs back last looked.
