I ran 2/0 welding cable for the postive through the firewall(the shortest most direct route from the positive 2150 terminal on the seperator). The ground from the engine block is also 2/0 and enters through the existing hole where the heater lines entered. I used silicone underneath and duct tape as backing to seal the area where the ground enters and from my experience that will hold up quite well and provide an even better seal than a rubber grommet alone which would have had to of been oversized and rectangluar. A rubber grommet would look better though it will not be seen anyway.
I considered a high amp dc circuit breaker, but a 300amp version was almost $200
(that's almost as much as the inverter itself). I think it would take a very severe crunch to even pose a threat (I just don't see it happening short of a semi-tractor falling on top of me from a bridge). I think it will be fine and after consulting with others opted to "risk" it.
