diff oil
Spokane Valley, WA
As always, I've done a search and am looking thru threads to find this but have not.
In my 95 FSM on p2 it says the front and rear diff oil is 75w-90
then down on p866 its got the transfer marked as 75w-90 and the differential as 80w-90
I just dont want to put the wrong oil somewhere.
Is the valvoline 75w-90 good for the diffs???
I use Valvoline stuff everywhere and it seems to be fine.
Try the synthetic or synthetic blend for the diffs.
why do you rec the synth or synth blend? notice differences after starting to use it?
what about in oil in the transfer case??? best oil?
I use Mobile 1 synthetic (75/90)and noticed mpg increase. Used it in the transfer case and f/r diffs.
how much better? I've heard w engine oil once you go synthetic, you can't go back... is that the case with diffs and trans case too?
go redline light weight shockproof in the diffs gearbox and transfer case 1 oil dose the lot and its great smooth shifts
Some people have reported higher oil consumption with synthetic motor oil. I tried Mobil1 it and my consumption went way up. So I just use dino in my engine. I have about 215k on it. But many have reported Shell Rotella is also good.
As for the non engine lubricants: if I can afford synth I use it, a synth blend is a little cheaper, and dino is
the cheapest.
I think the key is regular maintenance, not so much what you use. If you use synth, you can go longer between changes. I've mixed syn and dino with no problems.
I'm no oil expert but there are some threads with extensive studies that have been done on this great site.
my 4.5 80 dosnt use oil i do oil changes at 10 to 15 k and dont top up in between and all i use is synth oil and its done 350K
I have used synthetic oil for 20 years in various vehicles/engines. From 4 cylinder eco boxes to 8 cylinder BMW to a Mazda rotary. Mixing is no prob at all, you just wont get the full benifit. When I mixed it was from topping off with conventional oil. Going back and forth is fine,wont hurt a thing. The main thing is to check fluid levels weekly (at least) and stay on track with oil/filter changes and you'll be golden.
If you are already leaking then synth will leak even more, I know that for a fact as I have had a lot of leakers in my day. As far as my Cruiser goes, I have tried both Amsoil and Mobile and consumption did go up, nearly 2 quarts in 5000 miles. I'm back to conventional and down to 1/2 quart per 3000 miles.
