Diff lock light flashing
Lincoln, IL
I posted this in the Club Lexus forum and thought I'd post it here too.
While patiently waiting for my wife while she was in the grocery store, I pushed the diff lock button. The VSC light came on and the diff lock light started flashing. Now they will not go off.
Steering is now hindered as I assume the differential is either locked or stuck somewhere in between locked and unlocked.
I read up on the forum and I tried driving in reverse, which didn't help. I tried accelerating and decelerating while in reverse. I tried accelerating and decelerating while driving home. I drove circles forwards and backwards in loose gravel. Still stuck.
I wasn't far from home so I got her back to the garage. Now here I sit searching for what to do.
Does anyone have any advice? At least I didn't have anything planned for today.
Put the truck in neutral and the transfer case in neutral (parking brake on!) then push the diff lock button. The light should come on solid after a second. Then release the button and listen for the actuator and the light should go off. Put the car in park and the transfer case back in hi.
Update: Fixed
I took a rubber mallet and rapped on the actuator. I had my son push the diff lock button and the actuator moved and started beeping. The diff lock light started flashing at a slower speed in time with the beeps. I got into the drivers seat and pushed the button again and then the light went solid and the diff locked. I backed out of the garage and then pushed the button again and the light went out. Fixed.
It seems like the actuator got stuck trying to engage.
Very possible. If it is rarely used it can bind up with the grease being "dry"...exercise your center diff lock!
