Diff Lock Help (real time)
Cincinnati, OH
I'm about to change my rear brakes and rotors and i understand i should lock my diffs before taking the axle out.
So i put the thing on jackstands, went inside turn the key on (did not start it), put it in low, and then locked the rear diff (the light stayed on).
When i go to turn the wheel (price is right style) the wheel doesn't move. I was expecting the wheels to move in the same direction where as before they were moving in opposite directions with the diff unlocked.
Should i proceed like this, unable to turn my wheel or did i do something wrong?
If you took your driveshaft out they would turn, but the way it is now you are fine ;)
Put the xfer in neutral.
-B-
I normally back it into the street and then lock the diff and pull back in the garage. Sometimes takes a bit to engage, at least for the light to stop blinking.
No worries. The thing that makes the other wheel turn backward is the pinion being locked because you're in park.
Now the carrier is locked so it's all together.
As suggested, put the transfer in neutral - make sure the truck won't roll first - and they will turn fine.
Why do you need to lock the diff just to change the brakes? you don't even need to pull the axle shaft to replace the rotors they just pop off. Are you doing other work?
originally i thought i would do axle work while i was there, but i'm having such a hard time changing the shoes i'll prolly do all that on another date.
I found out the hard way. The wheels need to turn at different speeds for a bit to lock it up. Chock one wheel and turn the other one until it stops. Then you are locked up.
The question remains; why are you pulling the axle to do the brakes?
