Diff fluid change questions
Chino, CA
Newbie here. I recently got a 77 FJ40 and want to change all of the fluids.
For the rear diff, is it generally advisable to remove the cover, clean everything out, and replace with a new gasket? I'll probably go ahead and do this for the first time, how about on a regular basis?
Also, I was surprised to see no cover on the front diff. It is OK to drain, then spray some cleaner in there before filling? Or just drain and fill?
I have the factory Chassis and Body manual and the Haynes manual, but they don't really go into details on this stuff. I think they assume you know what you're doing for easy stuff like this :)
Thanks for the help.
Welcome.
Drain and fill for both, you should be fine, no reason to rinse.
If there are large chunks of metal on the drain plugs, then, I would investigate further...
Good luck!
-Steve
Sean, I think the big issue is water in the gearlube. I would just drain and refill. Don't spray any type of solvent in the front and unless you're a glutton for punishment or like the smell of hypoid, don't take off the rear cover, just change fluids and look for any sign of water in there.
Time would be better spent on rebuilding front axle knuckles. JMO
Ed
Or,
you could install a locker in the rear. This will require removal of the cover. Otherwise, do as Steve and Ed said.
Ken
Thanks!
Thanks for the great info guys! I'm all set to change out my tranny, tcase and diff fluids this weekend (all with 80w90).
The PO already put a Detroit EZ-Locker in the rear. Anyone have experience with that locker?
I will research rebuilding the front axle knuckles. That will be a challenge for me, but since it's not by DD I can take my time.
Thanks again for the info!
Sean.
Gear oil Ratings.
Hi All:
For the rearend, equipped with a Lockrite, Aussie Locker, etc. I'd recomend using 80W140 weight gear oil. For the tramsnission, t-case, or open diffs 75W90, 80W90, etc. is just fine.
HTH.
Alan
