if you need pics of anything, PM davegonz, his is nicely done. he's added a few addons from the initial Profftis conversion too. looking forward to seeing this, post pics!
I'll keep that in mind. been working with Jonesy on some of the small details. they started where Proffits left off. I'm not new to the cummins diesel an know the 700R4 is not the end all best option.
have a lot of little things to work on:
re-route brake lines (nicked one with the grinder while cutting the brackets off)
fuel delivery and return
radiator hoses
intercooler
seal 4bt engine
make TB TPS sensor bracket and throttle linkage
castor correction with coil-over lift
second battery
notch oil pan for better clearance than rub on bottoming out
bump stops
rear air bags to compensate for coil over front lift
a/c compressor and lines
alternator and fuel solenoid shut off
winch wired with original antenna up/down switch replace antenna with short flexible one
....many other small tasks
OK so there's a long list of things that will take more time than the physical install this week. but i am pumped to get this stuff working adn start to drive the cruiser again.
