Diesel Engine Swap Options...?
What are a few specific machines (other than Frito-Lay box trucks) that the Cummins 4BT came in, I've been searching with minimal luck for one of these engines. ( Sorry for the hi-jack, but it fits with this thread).
I was doing some research here and came across this thread. Planning to put a 1.9 VW TD from a 96 passat into my 67 fj40 as we speak. I'd also like to add that I am also a Master Diesel Tech. There is some good info in this thread but some sideways stuff as well. The modded 1.9 will EASILY make 230-240 HP and 4-500ft lbs if you let it. Now I will say that is about as far as you're going to go on a stock bottom end. You can go further these days however but reliability is going to suffer. I am mating mine to a W56 5 speed. You can get good clutches in this without all the bulk of some of the other transmissions out there. I could have gone with a v-6 version but I didn't really see a need. The only reason people don't make more HP with the 1.9 TDI's is the limitations of the stock transmission in the cars. Although I have heard of a few in the 325-350hp range that lived a while. The Toyota transmission fixes all of that and gives the advantage of 5 gears versus the 3 the FJ came with originally.
Now the comparison to the 4bt cummins, especially in the FJ40...well, lets just say I'm not a fan. having already been there and done that with a past FJ, I was not impressed over time. Now that is not to say it didn't work because it did. Just that the new of it in there was worn out quickly.. It went down the road fine, idled like a paint shaker. My 4bt was around 200 hp and between the heat, the weight, the noise and few other small issues I would never do that swap again. I'm not discouraging others, it just wasn't good for me and I'm a CUMMINS GUY!. I have been building the 1.9 in the Passat over time. Testing out the mods and screwing with it a little while still in the car. So far it screams. Injectors, turbo, head studs and few other little things and my little Passat is just over 200 at the rear wheels. When I finally get it where I want it, I'll yank it and drop it into the 40. OH and by the way? The little passat is still well into the 30's for fuel mileage. Now I know that will go down when it goes in the FJ but realistically, I should still see 27-30...maybe more. On an engine that I can't hear running with the hood closed. To me those things made the difference in the decision to swap this one.
I have had a SBC that I was going to stroke but did not like the birfields snapping or destroying the transfer case with the propeller support. So I started looking at the 4BT but they are rare and there did not seem to be much for support from venders.
Now I am making plans for a Cummins R2.8 with the H55f and split transfer case and a FJ40 ff axle. The 2F bellhousing behind the R2.8.
According to the manual my 78 FJ40 curb weight is 3880 lbs.
Do a youtube search for cummins 6at. Was an onan generator engine at first. Then cummins bought onan. This is a straight from the drawing board 210 cu in straight six turbo diesel IDI 3600 rpms. 120 genuine hill climbing HP, Direct replacement for a chev inline six. Same bellhousing. I am running an SM 435 because they are dirt cheap. Saw a lot of service in frito-lay and UPS light duty trucks. They were later sold in lots of ten . A Guy named 'royal rose put one in a fj 55. I am on my third one. I recently downloaded and printed a treatise from the Society of Automotive Engineers on the development of this engine. I have bought two off CL and one already in a 54 gmc.
My dream WAP would be a 1HD because it’s a modern Toyota, but it sounds complicated and a tight fit. It would be an epic build tho. A realistic swap would be a R2.8 tho because it’s smaller size wise and still somewhat powerful. 310 tourque isn’t bad at all
Wouldn't a 3B toyota from a rusty Canadian rig be a bolt in? I had one 4 years ago and sold the vehicle as parts with no title.
I’m not exactly sure how it would work switching from a F style engine to a B style engine, but I’m sure it wouldn’t be difficult at all. 3B is pretty good. Although, if I were going to a diesel, I would look for an H or 2H just because of power, and it sounds better. Those also came in 40 series land cruisers. (Well 45 but whatever. Same thing. Probably easy bolt in)
