Diesel engine gurus need you help.
i think my HD diesel engine has a back pressure..
what other engines can merge onto the HDJ tranny???
will a 1 kz fit?
i see a light smoke puffing trough the dipstick hole when i remove it....isnt that back pressure? when u are loosing compression???
nop .. it's just blowby and it can be fixed with a engine rebuild ..
1KZ-T aren't a good swap IMOP .. ( little engine for a big truck )
1HD-T / 1HZ / 1FZ-FE share the same bellhousing ..
you'll get more in the diesel section, try posting there... The most straightforward and cost effective solution, after you confirm the cause of the blow-by is to rebuild the 1hd-t. Having swapped a 1hd-t into a US spec 80 series with a 1FZ, I can tell you that while bolting the engine in is straight forward the electrical crossover between the two harnesses requires a lot of time, manuals and research, and hair pulling. You've got, arguably, one of the best power-plants Toyota ever made, in a stock configuration to boot, I think you'd be stepping backwards with an engine swap.
the tensioner is difficult
If I recall, there is a writeup in the diesel section.
I used a long screwdriver for leverage
actually....it came out very easily once u remove the main bolt from the centre of the bearing...and wetn back on easy....why i thought it was hard....is because i saw it on the net that it was.....yip and a long screw driver did the trick as well
so a 1fz will bolt on my 1hd tranny no problems?
from which Cruiser .. my first thought it's yes .. both should be 14 splines and 300 mm clutch ..
