Diesel Conversion Help...
Merrillan, WI
I'm new here...just got me a 77 FJ-40 and she's stripped to the frame. I've never done a frame off restoration before but I've got a base line of intelligence and a bunch of tools...plus I have a buddy that does restorations for a living.
Anyway, I'd like to switch from the 2F 4-speed to a 3B 5-speed. I've located a motor/transmission, now I'm trying to figure out how difficult this will be and what problems I should look forward to if I decide to do it. Anybody got any experience in making it all fit and work right? Any and all help is greatly appreciated. Thanks!
Torn apart in Wisconsin :hhmm:
IIRC, engine mouints, gearbox/trans mounts are different. Possible driveshaft issues.
Obvious wiring, fuel lines etc. Is the 3B from a 12v or 24v vehicle?
Mechanically, a 2H and 4 speed would be an almost bolt it.
I'm in the process (but only stripping the doner vehicle so far).
Driveshafts are an issue, try and get the ones from the vehicle the engine came from.
Vacuum: hopefully you got the alternator with it. You will also need a vacuum tank.
Radiator: ports are in different spots, so you may need a longer hose.
Glow plugs: if you are reusing you FJ steering column you need to add a switch for the glowplug relays.
Wiring harness: you need a BJ one, although some people have modded their existing FJ one to work.
Engine and transfer mounts: need them from a BJ, can be bolted in or welded.
Fuel lines: I believe you can just seal off unused lines.
Aircon: if you have it you need a new pump mount for the engine.
Thats all I can think of for now.
It's 12 volt...Marv from Spector Off Road has a 3B w/5speed...I'm trying to get as much of the extras as possible. Thanks a bunch for the help and if anyone thinks of anything else, feel free to share it!
Butch
Go to Canada
I would say look up in Canada. I just picked up an FJ 60 with a 3b and 5speed plus it has power steering and brakes to boot. I paid two grand for it. I'm in the process of pulling the 3b and 5 speed to put in my 77 fj40.
Good Luck:cheers:
Josh
