Diesel additives
Will it’s not quit stacks and there all for the same source.
I’m guessing that it’s from the the same group that’s pushing ultra low sulfur diesel.
I would be more swayed by some independent studies. 😉
Several of the studies aren't even from a US company. Neste is a finish firm.
I've owned a diesel since 2002 so while I'm not as old as some I do have some experience.
Took all of 5 minutes.
Hello,
It is hard to argue to SAE. Nevertheless, taking things with a grain of salt is at the heart of peer reviewing.
One article mentions the usual suspects, namely thiophene, and the detail that multiple samples from different sources were tested. Another article from Europe mentions test rigs but not the sources of their fuel. Two articles mention the use of lubricity additives in low sulfur diesel from California, complete with test methods.
There is a mention of hydrotreating as a way to reduce sulfur. Since this process is also used to produce linear hydrocarbons, which are not very good lubricants, the concern about lubrication loss has a ground.
The stack, as it is presented, supplies reasonable evidence that low sulfur diesel used in California -complete with test method results- does not show changes in lubricity as a result of sulfur reduction by hydrotreating. It also says that Californian refiners used lubricity additives in low sulfur diesel.
As for the stack portion that does not mention Californian diesel specifically, the jury is out. Nice description on composition and hydrotreating, though.
Juan
Hello,
Juan
A grain of salt is always valid. And additives don't hurt anything. I use them on occasion. But I think the adage that just because it's low sulfur it's bad is not accurate.
Hello,
At least not in California, as per the stack you supplied. And that includes the use of lubrication additives in the fuel.
Juan
