Did the 80 ever...
The part number on the block heaters kup99 and I installed was: C0140-00134-S2. The instructions for this one said to install it on the intake side. I think the part number that ends in 144-S2 is meant to be mounted on the exhaust side. I can't see the element being any different, maybe just a cord rated for higher temp. Neither side looked easier to do the install on to me, but see what you think.
Doug
I watched the show "Trick My Truck" on CMT I watched them pull the heat pads from the back side of a heated mirror.....and ever since then I've wondered if you can wire them with a momentary toggle switch and either place the pads into or onto any pans, this would heat the oil quicker and although it would not be a block heater it would heat the engine up faster and you would be staring it with warm fluids.....
wonder if it would work.....?
seems like it would be cheap too.
The make those already too.
Got models for oil pans and lower heat ones for batteries.
Got a diesel get an ESPAR :grinpimp:
Doug
Yeah, I think this was mentioned in another thread. Mine (144) had an extra woven sleeve on top of the first length of the wire. I found the exhaust side quite simple (once I worked up the courage to put a hole in a perfectly fine engine block :D). Just take of the heat shields and intake tube, and rotate the air can spout towards the front for extra elbow room. 1 :banana:
Engine Heaters
IMHO hose mounted heaters are not the solution when things get below 0. They heat the water in the hose and it will circulate by convection through the radiator and that is not where the heat is required.
The New Zealand Antarctic program uses 70 series toyotas down at Scott Base and they have hose type heaters plumbed into the heater circuit and these circultae the water through just the block portion of the cooling circuit. Block temperatures of 70 C are easily acheived. The vehicles are also fitted with cab heaters to ensure that the cabs are not so cold that the Inertia reel seatbelts do not function. Battery heater blankets are fitted to yellow top Optimas.
Larger items of plant are fitted with heaters to directly heat the oil in hydraulic tanks and the sumps of buldozers.
Even so at -50 gear changing with a maunual transmission can be fun. Also starting the vehicle require depressing the clutch even when the vehicle transmission is in Neutral to prevent forward motion purely due to the viscosity of the oil.
