did a SR today
Changed the tired motor in my 78' the day before yesterday stuck an sm420 and three speed case .Did a shackle reversal today going spring over with 55 springs in the rear detroited in the back with 4.88's still have to go saginaw power steering but I have most of the parts just waiting for a couple of things from Kurt . I'll try to post new pics everyday .Anyone know how to put more pics up I've had the problem in the past where I run out of the space allowed me.
Get a star..
Additionally, why the drop on teh front spring mount??? Running 42" tires or larger?
what do you mean get a star ?The reason I drop the front of the spring is so that it sits more like stock as far as travel goes the wheel will travel more staight up and down than up and back .It's slight but I've done couple this way and it works well.
Are you using stock/flat springs and, what size tire are you going to run with your set up?
you get a star next to your nick name if you pay a small fee (or donation) and then can post lots of pics and some other goodies. woody has a post about silver star membeships if you look for it. look at the top of the forum list it says
anouncement silver star membership.
I am going to run the 35's I had on it for a month or two but I was thinking I'd put some 36" TSL's on it. i am running stock springs (with the exception of the 55 springs) I'm going to try to get around a 100 " wheelbase , primarily to be used on the trail .
made some custom pins today for the back . Had to open up the holes a little in the hanger eye to fit the 55 pins .I then made bolt plates and welded them to the 55 pins. What do you guys think of running the military wrap on the rear spring on the shackle end . There isn't really enough room for the wrap at the front with the modified 40 hangers,they rub on the top .
I'm in the process of doing the spring over too and I just picked up my 55 rear springs today from pighead... BTW he kicked down a 1/2 off sushi cupon too! Thanks man!
couple questions for you. First, what legnth are those shackles from pin to pin. And second, did you relocate rear spring hangers for your 55 rear springs or are they in the stock location.
Thanks, mike
the shackles are 6.5 inches overall the pins are centered 1" from each end so i guess about 4.5" center to center and yes i did flip the rear hanger I think it moved it back a couple of inches i used the rivet holes for my rough line up.
It really depends if you like replacing broken springs on the trail.
If you don't mind it, then by all means leave the military wrap at the shackle end.
The springs i'm using are in very good condition . I was thinking If this truck works out well I'll probably four link in less than a year anyway.Has anyboy had alot of spring problems in the past as far as broken ones go.I've never busted one .
If you do not think there will be a problem then please, go right ahead..
rear end placement
I redrilled the spiring perch in order to move the axle back an additional 1.5". The side view shows where the wheel ends up in relation to the body.
