Got a little problem here and I need some ideas.
When I turn the key in the ignition, it cranks fast, then slow (very slowly), then usually starts. Sometimes it cranks fast, then slow, then fast again.
I had a two battery setup and thinking that had something to do with it, I removed both batteries and replaced with one brand new one.
After I put the battery in, it cranked fast, then slow again and finally started.
I've read in other posts that this could be a symptom of a couple of things...bad starter or timing too far advanced (?).
Question is...how dow I go about diagosing what the problem is? My thoughts are just replacing the starter...
Thanks!
Thanks!
