My '97 has 246k. When driving over bumps with a window down I hear a clunk that sounds like metal on metal. The bump in the road could be as big as a speed bump or as small as a large crack in the asphalt, and it happens virtually every time.
Front axle service was completed two years ago with new bearings, birfs, rotors and pads. I've checked the hubs recently, and they are sufficiently tight. Sway bar bushings look good.
After doing a lot of reading on here I'm nearly convinced it's the tie rod ends, but everything I've read also mentions a clunk when turning, and I don't have that symptom. Mine only clunks over bumps.
I slid underneath the truck last night and while grabbing the tie rod with one hand was able to rotate it easily until the ends knocked, generating a clunk that sounded similar to what I've heard while driving. Should the tie rod be that easy to rotate and cause a clunk against the tie rod ends or should it be harder to move? Am I right to think it's the tie rod ends or is there another possible culprit I'm overlooking? Finally, if it is the tie rod ends, is the recommendation to service them with grease or to replace. I've read threads on both, and it sounds like a bit of a pain to replace them, but regreasing alone may not be sufficient. Thanks in advance for any insight you can offer. You guys are great.
