Detroit locker question
Well, first off we don't know what you are trying to put it in...
But assuming it's an fj or fzj 80...no
From what I can tell, that detroit is for an 8" Ring gear
It may work in the front but not the back...
I don't know if that's a good idea on a fulltime 4 vehicle
Someone else chime in?
Sorry, let me clear it up a little. You can buy an 80 series high pinion from Marlin or whoever, to put in a front truck axle. I already have a Detroit for a 8" 4cyl and I was wondering if I could install it in a high pinion instead of spending the $ for a complete third with a locker.
In my books are not a good idea ( or at least I don't recommend it ) run a auto locker in front of a full time 80 ..
It's going in a mini-truck front axle. I'm just wondering if the Detroit is the same for a mini-truck, and a HP out of an 80. I read somewhere on here that a True-Trac (LSD) would work, but it was in reverse rotation and weaker that way, due to the internals of the LSD. Detroit makes a full locker for the 80 high pinion and I was wondering if anybody knows if that is the same locker used in a 4cyl mini-truck.
You're in the wrong tech section... And it doesn't look like it...
A HP front is the same carrier as the Turbo or V6 rears in Mini's.. http://home.4x4wire.com/erik/diffs/#hipinion
‘90-97 Landcruiser (FJ-80 and FZJ-80) uses a high pinion, reverse-cut front diff based on the V6/Turbo rear diff. The high pinion design allows the steering on these vehicles to run behind the axle and under the driveshaft. Carriers (i.e. lockers, LSD's) from the 8" V6/Turbo diffs can be installed (direct bolt-in) in the hi-pinion diff. The entire diff is also a direct bolt-in to all front and rear axles that use an 8" diff.
This diff is desirable to some straight-axle mini-truck and 4runner owners for a couple of reasons. First, the reverse-cut design of the gears is stronger than simply using a rear diff and gears up front as the factory did since its not using the weaker "coast" side of the gears when driving forward. For this reason, this diff is generally only used in the front axle. Second, the hi-pinion design gives very good ground clearance for the pinion and driveshaft as well as improves driveshaft operating angles.
In North America, almost all of these diffs came from the factory with 4.10 gears. Aftermarket gears for this diff are more expensive than most since they are either imported or custom made in limited quantities. At this time 4.88 and 5.29 are the only aftermarket ratios available.
Erik's Toyota Differential info
"4cyl 8" diff carriers (cases) do not fit without custom carrier bearing adapters ($), try Inchworm Gear"
You can also read on here where a guy took his apart, flipped the case over, and put it back together...
And yes, that's how it's supposed to work... And that's how you make it work in a Reverse Rotation diff.
I can TRY and find the link... But won't if you're not interested...
let me know...
