Detonation? Is there a fix?
If you listen for It, you should be able to hear a motor ping.
Another sign of too much advance is if your motor diesels when you shut it off.
I've had the same problem when I don't use premium unleaded gas. It shouldn't be a problem with a 7.8:1 compression ratio but it is. If I back off the timing, the engine runs hotter so It's definitely a trade off.
I run with the stock timing and with premium gas...just the cost of running a cruiser :) .
