determining u joint needed
I have a 72 with a 772f engine and a 4 speed . I did neither of these changes and when I pulled off the rear driveshaft to get to my emergency brake I notice my u joints were worn down and I want to replace them. I see there are u joints for up to 12/73 and than a different one starting 1/74. I have 2 questions and forgive my ignorance please.
1. When he or whoever put the 4 speed into my 72 would he have had to change the drive shafts to match? which means i need to replace the u joints with the 1/74 and later ones.
2. How do I tell what style u joint is in there now are there part numbers that will tell me? Is it size based?
Thanks
4sp U joints are larger than 3sp. It is possible that you have 2 3sp; 2 4sp or 1 of each, depending on how the swap was done. If the retaining bolts are 11 mm in diameter, then it is a 4sp joint.
Don't use Neapco brand joints. They don't fit no matter what they think.
Get factory Toyota.. It is MUCH stronger than pepboys/Autozone..
Thanks I'll check out the retaining bolts and go from there. CCOT sells the u joints are their aftermarket ones ok or should I buy toyota?
Buy toyota...
Again, buy toyota...
Stronger than spicer stuff..
