- Joined
- Apr 21, 2005
- Threads
- 115
- Messages
- 25,822
I do not plan on making beach driving a regular thingThe sand gets everywhere
You do know it's not the sand that your biggest problem. Salt should be your main concern. You drive thru the surf and your going to find rust leaking out of everywhere. Under your gas tank isn't sealed. The weatherstripping between the windshield and cowl. Inside your hub caps are famous for rusting. The lip helps keep in moisture. If you make this a regular practice your going to start finding surface rust pretty quick. It's your vehicle and if that want you want to use it then go for it. Me the only vehicle that see salt is my 100 series. That only because it's the only way I can get to my cabin in the winter time is to drive on salted roads. The cruisers that I keep up north do not run on the highway until after the spring rains start and wash the roads off.
Here is a link to a highway camera close to my cabin. Certain times of the day your can see how stained white the road is with salt.
ADOT's Rural Weather Information System
John
