If you tap a bit in the screw firmly with a brass hammer, a good solid hit, they will usually come right out. I usually use a small sharp flat chisel to loosen stripped screws by hitting the chisel into the edge of the head and then hit it in the direction to loosen it. This method takes patience, but it works. If the screw is very damaged, then drilling the head off may be the best way.
