Desmog components
Status
Not open for further replies.
What are folks using to plug the EGR port on the intake? I used the blockoff down on the exhaust one. I don't have access to a welder.
The 2 BVSV plugs are included in case both are broken. It's up to you if you decide to remove the unneded one and the broken one, or if you get a new one to keep the evap system functional.
With gas at $4, I would try to keep the evap functioning so I wasn't pissing away expensive fuel vapor all the time.
On second look they both had a broken nipple on them...I'll have to order a new one & read up on the evap system in the emissions manual.
Worst case, it may be necessary to unbolt the PS bracket from the side of the block. 3 bolts and one nut, all 14mm hex. Easy.
Yeah, that was about the only way possible...I tried yanking it out a million different ways...haha.
put the belt on the idle pulley and the waterpump, then go under and put the belt on from there, seems to work the best for me
and I dont know how many years my AP was out, but i recall it made noise for a few years, as I dont drive it much it may have been out since 1999.
I might be imagining things but the ole 60 really gets up and goes now, hoping it may have been the reason I was getting 8mpg and I swear it use to get 12mpg in town
Trick to getting belt back on the idler pulley? I have it adjusted as far front as it goes and can't get it on...
hey Jim -- i am ready to purchase the desmog kit - you emailed me a invoice a while back -- i am now broken down and really need it -- if you could email me back so i can pay with paypal -- thanks hward13@juno.com
hey jim - was wondering if everything was being shipped -- also you dont happen to have for sale a intake manifold do you -- i noticed mine is cracked after removing everything -- hward13@juno.com
1- got a intake coming from georg
2- do i use anything around the hex screws when i get them
3 - how many of the felpro gaskets for the manifolds and for the egr port spot do i use felpro also and how many of those (double up or just one)
thanks
hward,
The dissy is being built now. The finished dissy, idler, plugs will ship tomorrow. Carb to follow ASAP.
No, I don't have a good intake available.
No, don't use anything on the AIR plugs. I do recommend using teflon paste on the BVSV plugs.
Make everything correct and use one good gasket.
Jim, sent you payment of $23 for caps&plugs.
Cap and plug set
Jim, just paypaled $15 for a cap and plug set.
Thanks
hey jim - do i need number 45 mine is cracked --
Yes, typically a source of manifold vacuum is needed to power the Dissy vent. A 1 or 2 or 3 port fitting will work for a desmogged truck. They can be had at PNP for a dollar off any old toyota engine.
When I put my plugs, I did find that small plug is too big for my Air Cleaner assembly, while the big plug fits perfectly in.
Status
