Well, I have never seen any skidplates made for the 80 series so I designed my own. This is 3/16 aluminum and is quite beefy. It does reduce front approach angle by about 2 inches though. It was bead blasted and this gives it a smoother look. Ya'll think I should get it powder coated..or maybe shorten the "fangs" more?
airlaird
airlaird
SAme Q here..I know it looks cool, but everytime I've hit that area it equal the tow points or the frame rails and they don't really need protection. it does look cool though. Nice work
Nice Skid plate but I am curious as to why you have the fangs on the front. I just had a piece of steel plate folded similar to your so the front tucked up behind the bull bar and the back flap is folded down just enough to protect the steering damper.
I built my Skid plate because if you looked under the bull bar you could see the radiators there just waiting to have a stick rammed through them on a trail.
My plate was made of 6mm steel and now also has a winch mounted on it at the best height to get the wire straight out the fairlead. I do not like the winch mounted right behind the front of the bullbar as I have found that the more distance between the fairlead and the winch drum the better the cable will self lay onto the drum.
Several years ago I actually dented the "piping" (I am not sure what that is...the tubing or condensor that sits right at the frame??). Anyway, this should help that from happening again.
airlaird
airlaird
excellent skid. I build a not as sexy one for my truck after almost wedging a rock in that space your skid protects.....only problem is that if we are sliding over stuff that high with our skids the next stuff to get smashed is steering linkage
airlaird,
nice work, it looks neat. I don't know if it's a bit much tho- the front part of the skid seems unnecessary.
here is a simple one that Inverness fabbed- I like the idea of protecting that ps line, it does seem vulnerable (yet actually doesn't seem to get trail damage)
airlaird,
Firsttoy, Great skidplate. I can't go your route...My design MUST be attached at the the steering stabilizer.
My non winch ARB bar has no such place to attach a plate such as yours...there are no such attachment points under my ARB bar like your pic shows...
airlaird
Well the "fangs" don't really do anything....I call it a "design"...much like the lines in the hood of our cruiser's...much like the stitching in our jeans. There's no function to it...therefore it is simply a "design" . Hey it sure beats a steel plate right?
airlaird
