Depo headlight adjustment
Lubbocm
Hey guys, dumb question I know but does anyone have a good write up for adjusting depo headlights? Having some trouble.
Ehhh the one thing that sucks about the depos is that they use the ECE (European) cutoff. So the beam cutoff angles up to the right halfway through the beam. Some love the ECE design, I'm meh about it. Since I'm using high quality LED bulbs my light output is greatly increased yet the cutoff remains fairly crisp, however, the angle up nature of the ECE design is not typical in the US so people in front of me tend to think I have my brights on.
Anyway you aim them the same way you would aim regular DOT headlights. Here is a link
Thanks! It looks like there are 2 screw adjusters facing up with the depos. Are those the only two to use?
No the two that are facing up are the vertical adjustments for the high and low beams, the horizontal adjustment screws are facing the firewall and are kind of hidden by the front cross member, if you stand at the fender and look in from the side you should see them.
You will need to remove the coolant overflow reservoir to access the one on the passenger side.
Be gentle with the adjustments, if you get all the way to one end of the adjustment and keep torquing they will strip out.
