Definitive VC Question
That was a good read, thanks. That still leaves me with a question though; When the VC is removed, does all the power go to the axle with the least amount of traction? For example, if the rear end is on pure ice and the front end is on solid ground, and the center diff and front/rear axles are unlocked, will just one rear tire spin (tire with least amount of traction out of the four)?
Yes.:steer:
Another question: If someone made/fitted a pinion/driveshaft brake to the front driveshaft, would this serve as another version of a part time 4wd kit?
The brake would keep the front D/S from turning by offering more resistance than the rear axle.
If you kept the front tires off the ground, maybe, and with the VC removed. If you want part-time 4wd, you'll be needing (un)locking hubs.
-Spike
I don't understand why you'd need selectable hubs if you can keep the front d/s from turning. It's all hypothetical since I'd like to find a VC to replace mine but I'm trying to gain as much understanding of the system as I can.
Another question:
With the VC removed, and no center diff lock switch, do I effectively have 2-HI and 4-LO? With the CDL switch, I expect to have 2HI (CD unlocked), 4HI (CD Locked), and 4LO (CD Locked and TC in low range). With Pin7, I would also gain 2LO (CD unlocked and TC in low range).
*By 2-HI, I don't mean RWD HI, I mean whichever axle has the least traction 2HI.
Because if you stop the front driveshaft, you stop the front axle. The tires won't turn.
In the 80 series LC, there is no such thing as 2-anything. It is all wheel drive, or 4 wheel drive. All wheel drive if the CDL isn't locked- all wheels under power, but if any wheel loses traction all the power will go there (discounting the effects of the VC). With the CDL locked, at least one tire on each axle will turn. With axle lockers engaged (if equipped), all 4 tires will turn.
-Spike
-Spike
Ok, I see, that makes sense. I forgot about the tires turning the pinion part of the equation.
I still don't understand the AWD theory when you have an unlocked center diff and no VC. If the axle with the least amount of traction gets all the power in that condition, isn't that effectively the same as a 2wd truck?
Quote:
Tools R Us says "Yes.:steer:"
Your statement that "the axle with the least amount of traction gets all the power" is almost never the case, unless you're stuck and spinning a tire. There's almost always some power to the front, some to the back.
I still don't understand the AWD theory when you have an unlocked center diff and no VC. If the axle with the least amount of traction gets all the power in that condition, isn't that effectively the same as a 2wd truck? ...
Pretty much one wheel drive, jack up any one tire and your not going anywhere. But in normal conditions it makes for a great handling, high traction setup, this is how most AWD cars are setup. Because the drive is split over 4 tires, rather than the normal 2, it's much harder to get one to spin, each tire has effectively half of the drive torque when compared to 2wd.
I think we're on the same page, we were just saying it differently. It's probably my bad for not being the best "explainer".
1)When all four tires are getting equal traction, both driveshafts are turning, and both axles are getting close to equal power.
2)When all four tires are getting unequal traction, the power is diverted to the axle, and then to the wheel, that has the least traction. This is the same as an open diff in the rear end of a vehicle.
With a VC, the effect of Point 2 is lessened since it acts as a LSD. Without the VC, you're effectively screwed (until you lock the center diff) if you're going slow and lift one tire in Hi. That tire will receive all the power and since you have no momentum, you'll just spin that tire and not make it over the obstacle.
So to revise my previous statement, when you're off-road with no VC and the CD unlocked, you're more or less in 2HI. Not technically, but as soon as you lift a wheel or one tire loses all traction and starts spinning, your truck will perform just like a truck that is equipped with 2HI. If you have the switch and you lock the CD, you're then in 4HI, and if you drop the T/C to low, you're then in 4LO. With the Pin7, it gives you 2LO since you can drop the T/C in low and unlock the center diff.
Not having a VC probably makes the biggest difference for those that use slippery boat ramps, don't have the CDL switch, and don't know to go to 4LO to make the front wheels pull.
BUT, if you have the CDL switch, understand that for off road with no V/C you might as well lock the CD, and realize that on ice and slippery conditions you're driving an open center diff vehicle, you should be fine.
I for one like the VC, anything that gives me more traction is a plus but the reported $900-$1000 to replace one could be spent on far better mods.
If I do take mine out, I'm going to cut it open on a lathe and see what's what. Maybe it can be repaired?
Sounds like you have the operation theory down. If the rig sees significant snow miles, I hear they work well, but mine has seen maybe 10 snow miles in the last 60K and I don't see that ratio changing, so I would prefer the added fluid capacity and would remove it if it went bad.
I have a locked one, IIRC it's a welded, non serviceable unit, it has a date with the band saw and/or lathe sometime in the future.
